transmission gear problems
Old Dec 4, 2002 | 10:31 AM
mRvYbEs's Avatar
Default transmission gear problems
I have a problem with selecting gears. When my engine is running, I'm unable to select any of the gears. If I yank the shifter really hard it sometimes go into reverse. The strange thing is when the engine is off all the gears can be selected. I've had a (ACT) clutch in for a year and I don't think it's the clutch. Does anyone know what the problem could be?
Old Dec 4, 2002 | 10:55 AM
Dave-ROR's Avatar
Default Re: transmission gear problems (MRVYBES)
clutch related. sorry.
Old Dec 4, 2002 | 01:42 PM
Dave-ROR's Avatar
Default Re: transmission gear problems (DOHC_VTEC)
Sounds like a clutch master cylinder... check your clutch fluid level y0.
could be anything clutch related actually.
Old Dec 4, 2002 | 04:02 PM
markpaco's Avatar
if your freeplay on the clutch is less than 1/4" or so, you may have that problem. Go under the dash and adjust the stop to allow for more freeplay. You won't be able to shift if the clutch is warm and/or rotating. With the car off, you will be able to shift.
d_fuentes
Transmission & Drivetrain
Dec 17, 2016 10:15 PM
user 69782342442
Classic Hondas
13
Jan 25, 2010 01:52 PM
92-EG6
Aug 25, 2003 10:02 PM
Suave99
Apr 25, 2003 08:13 PM
joel
Sep 10, 2001 08:53 AM
