trans problems
Old Dec 25, 2006 | 06:37 PM
Funkin Flux's Avatar
Default trans problems
Hey wassup i got a 00 itr. question My 3rd gear grinds at high rpms. I bought it with a stage 3 clutcmaster kit. Would i need to replace anything? Thanks
Old Dec 25, 2006 | 07:53 PM
neo_'s Avatar
Default Re: trans problems (Fluxy Poo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fluxy Poo &raquo;</TD></TR><TR><TD CLASS="quote"> Would i need to replace anything?</TD></TR></TABLE>
Yes, your 3rd gear syncro. Or you can use some GM SyncroMesh Friction Modified trannsmission fluid as a band aid.
Old Dec 25, 2006 | 08:01 PM
thnx neo appreciate the help.
Old Dec 25, 2006 | 08:56 PM
totsie7944's Avatar
Default Re: (Fluxy Poo)
yea man ITR's are FAMOUS for that 3rd gear grind.....I would suggest if you have the know how to replace the syncro, but tranny work can be very touchy if you don't have experience doing it. Syncromesh seems to work for alot of people, and as long as you don't drive the **** outta your R on the daily basis you should be fine with the mesh....
Old Jan 1, 2007 | 06:15 PM
Quickridez_3's Avatar
i just got that problem on my 00 type r like two weeks ago i used the royal purple sycromesh it works but it grinds sometimes it seems like after ive driven it hard all day it grinds but if i just started driving it hard it doesnt grind is there a big difference in using the gm sycromesh?
Old Jan 1, 2007 | 06:30 PM
RTW DC2R's Avatar
gm synchromesh may work as a band aid. it worked great on my car for like 2 yrs. but if its grinding, you probably have damaged synchros and will eventually get worse. after I boosted my car, my trans went downhill fast (bearings and synchros).
flatblack-h22
Jan 21, 2008 06:05 AM
Wazup
Oct 25, 2007 02:47 PM
LetAGrlShowU
12
Sep 13, 2007 11:13 AM
fyr3
Apr 25, 2005 12:27 AM
undercoversi
Jan 17, 2005 03:07 PM
