Thermostat, but how come two part numbers??
Just looking at oemacuraparts.com and trying to order some tune up items and thermostat.
Here is what are listed,
3 19301-PAA-306 THERMOSTAT ASSY. (NIPPON THERMOSTAT) $23.15 $16.67 1 Add to Cart Add to Cart
3 19301-P08-316 THERMOSTAT ASSY. (NIPPON THERMOSTAT) $23.15 $16.67 1 Add to Cart Add to Cart
So which is the correct one?
Here is the rest of the parts list,
1) CAP ASSY. (distributor cap)
Product ID: 30102-P72-006-Acura
2) HEAD ASSY., ROTOR (distributor rotor)
Product ID: 30103-P73-003-Acura
3) GASKET, CAP (distributor cap gasket)
Product ID: 30132-P72-006-Acura
4) GASKET SET, HEAD COVER (valve cover gasket + spark plugs tube seals)
Product ID: 12030-P73-000-Acura
5) RUBBER, THERMOSTAT MOUNTING (thermostat rubber seal)
Product ID: 19305-PT0-000-Acura
6) Thermostat, but don't know which one
Please help me out as i am ready to order, thank you in advance.
Superseded part number most likely.
19301-P08-316 is the most current for all models. ITR/GSR/LS
Edit: Just looked at the Honda part # for a B16 and it is listed as 19301-PAA-306. So I don't know if that's an old number or what. I assume both thermostats are the same.
dont need 19305-PT0-000(comes with thermostat)
also dont need 30132-P72-006(comes with distributor cap)
19301-PAA-306 thermostat
30103-P73-003 HEAD ASSY., ROTOR
30102-P72-006 CAP ASSY
12030-P73-000 GASKET SET, HEAD COVER
are the #'s you need might as well do cam cap also if your not getting a billet one
12513-P72-003 PLUG, CYLINDER HEAD
Thank you so much.
I thought about the cap gasket and thermostat gasket being individual item, thank you for your pointers.
19301-PAA-306 IN THEMOSTAT YOU NEED
crvglenn
Honda CR-V & Element
Sep 11, 2017 03:42 PM
19301paa306, 2002, a4, acura, audi, ep3, honda, integra, number, oem, part, performance, powered, thermostat, vbulletin
