Distributor O ring leak
What does it leak ?
Do you mean that moisture can get in the distributor cap ?
You could always try high temp liquid gasket (the same stuff used on the valve cover gasket to seal the corners).
I replaced the O ring with a new ring, and it still leaks.are your sure the oil is coming from there?
It could be the valve cover gasket leaking from one of the corners in that area. You could remove the valve cover and inspect the gasket to see if its not damaged.
I doubt it would be the head gasket leaking oil
