shift knob
shift ****
hey guys i have a 1999 civic dx sedan, and my shift **** is fine but the shift boot is probably broken, because i can see the metal part of the shifter, there is a gap between the actual shifter and the shift boot so idk how i can get rid of that gap other than buying a new shift boot.
Re: shift ****
put the top of the inside outboot (skinny part) where you want it, zip tie it tight. trim off excess TIEwrap. flip boot back over and put into place replace ****
Re: shift ****
but if i wanna take off my shift boot, then that takes more work than just pulling it off... you have to remove the plastic around it
New User
Re: shift ****
alright, so honda prelue shift boot to the **** is square... i've tried unscrewing the shift **** to get it off but the boot justs twists with it till it won't twist anymore and it won't disconnect. how do i get it off?
Re: shift ****
i have same problem i just stuck my hair tie under it. just get a new shift boot and zip tie underneath it before you put the new one on. pwjdm sells them for cheap like 30 bux maybe u can even get it for 20. or you can get the honda one i think its like 50. theyre easy to remove you just have to take that whole platform off. the center console thingy next to the shifter and ebrake
PatrickGSR94
04-04-2010 09:03 AM
