Random misfire engine code please help
Old Oct 9, 2002 | 11:39 AM
JPP's Avatar
JPP
Default Random misfire engine code please help
For the past two weeks I have been having the engine light come on for no apparent reason with the codes 71 72 73 beeing displayed each time. The CEL only comes on during idle. Yesterday I got tired of it and started checking everything I could following the Helm recommendations: compression is good, gas pressure is good, injectors seem to work fine, ignition wires are within spec reistance wise (well below 25 kohm). However when I was checking the ignition timing, I noticed that the strob light would jump a beat once in a while. This only happens on #1 piston. I switch spark plugs between #1 and #2 piston to see if the problem would switch to #2 piston but it didn't.
The only possibilities left is that the #1 ignition wire is no good, the distributor has an intermitent problem occuring only when feeding #1 piston or, considering that I am getting three error code when I found only one piston with ignition problem, the sensor is defective.
Am I missing something ? Before I go an buy a new set of ignition wires or a new distributor (rotor,cap or complete assembly) Is there an avenue that I did not explore?
BTW wires, dist. cap and rotors and plugs have no more then 4000 miles on them.
Also the problem seemed to have started when I installed a lightweight flywheel (which could have increased the detectability of the misfires)
Thanks for any help.
Old Oct 9, 2002 | 11:43 AM
reefer_bob's Avatar
Default Re: Random misfire engine code please help (JPP)
My guess, is that if you installed a flywheel, which is right underneath the distro, that somehow the distro cap got damaged in installation. Try checking the wires and wiggle them as well. I'd say a new distro is the solution.
Old Oct 9, 2002 | 11:45 AM
sgT's Avatar
sgT
its the lope from your cams causing the misifire codes.
Old Oct 9, 2002 | 11:58 AM
JPP's Avatar
JPP
Default Re: Random misfire engine code please help (sgT)
Would an increased idle speed via the throttle body bypass valve solve the problem?
Old Oct 9, 2002 | 12:05 PM
JPP's Avatar
JPP
Default Re: Random misfire engine code please help (reefer_bob)
I was so carefull no to damage anything when I reinstalled the FW, clutch and tranny, I looked like one of those bomb squad expert in the movie trying to disable a nuclear weapon : "be carefull !!! don't touch the armature, don't touch the armature..."
Old Oct 9, 2002 | 12:09 PM
sgT's Avatar
sgT
nope. its just one of those things. ecu is very sensitive for some reason.
those codes will come and go
Old Oct 9, 2002 | 12:15 PM
JPP's Avatar
JPP
Dang !!! I hate that yellow light !!! I'm gone have to find a way to reset the ECU from inside the car then
Thanks for your help
[Modified by JPP, 4:28 PM 10/9/2002]
Old Oct 9, 2002 | 12:33 PM
reefer_bob's Avatar
OBD I ECU!!!
damned caps lock editor...
Old Oct 9, 2002 | 12:43 PM
JPP's Avatar
JPP
OBD I ECU!!!
I had the chip reprogrammed on the dyno and I don't know if it would "work" in a OBD I ecu. Plus I like having codes telling me if something is wrong with the car but it is kind of annoying when it is a false alarm (like a radar detector that is too sensitive)
Old Oct 9, 2002 | 12:47 PM
ITR21's Avatar
i had the code and it was because my plugs were bad.
WhitelightningEX
Aug 9, 2006 07:37 PM
pulse_crx
12
Oct 24, 2003 05:33 PM
Patch
Jun 8, 2003 04:14 PM
Smurf
Audio / Security / Video
Aug 21, 2001 06:13 PM
BLKMamba
Aug 6, 2001 04:56 PM
