QT: Troubleshooting with 00 Itr Trunks, Need a part number n name preferrably
I'm having problems with my rear hatch to open lately. Last time i got it checked out the shop mentioned that the mechanism that locks n opens it is laggin or not fully functioning. It didn't matter to me since I rarely use the trunk anyway, but today it wouldn't open whatsoever, tried auto open then lock and also with the key. After half an hour of trying still no prevail. So I know it will eventually open sooner or later but to eliminate the problem i'd like to replace it. Now since i have no clue on what its called, can someone help me in finding what part number it is as well as the name for it, Or if anyone has a spare that would sell it i'd appreciate it. Again its the mechanism that allows the trunk to open(not the trunk switch that's attached to the trunk) and close.
thanks
~paul
thanks
~paul
Location: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Re: QT: Troubleshooting with 00 Itr Trunks, Need a part number n name preferrably (Kicker773)
its a common problem with 2000's. The latch doesn't click back right? Gay Will had the same problem with his trunk and sometimes the latch doesn't lock on. Lube it up and readjust it frequently.
Re: QT: Troubleshooting with 00 Itr Trunks, Need a part number n name preferrably (Nvious R)
damn imma have to lube it up...lol.. it opened today.. i just need it to open tomorrow for a pick up from minnesoata dropping by
Is the ITR trunk releave like the 98-01 Integras? Meaning, it is an actuator or is it cable release system like 94-97?
I just know this ish is expensive from the dealer, over $150 and change
from time to time I have a problem closing mine, but when it sticks I use some wd40 and saturate it then I get many months of headache free use.
Still might be covered under warranty depending on when the vehicle was first bought.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 »</TD></TR><TR><TD CLASS="quote">Again its the mechanism that allows the trunk to open(not the trunk switch that's attached to the trunk) and close.</TD></TR></TABLE>
If you open it with the switch by the driver's seat does it work?
Re: QT: Troubleshooting with 00 Itr Trunks, Need a part number n name preferrably (dc2Rgirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2Rgirl »</TD></TR><TR><TD CLASS="quote">
If you open it with the switch by the driver's seat does it work?</TD></TR></TABLE>
only the '97s have the cable hatch release here in the states.
Re: QT: Troubleshooting with 00 Itr Trunks, Need a part number n name preferrably (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">2001 don't have that switch maybe other years too</TD></TR></TABLE>
its odd, i've never seen that problem with 01's! Its always been 2000's that have that problem.. hmmm
Collector-o-Guns and Drinker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">2000 don't have that switch </TD></TR></TABLE>
Yep, they were electric. Never had problems with mine, but I only kept the car 2 and a half years. I wonder if this is an age/use issue?
nope
its either #15 or #25.. the 00-01 are different form the 97-98
nope
anyone have a spare lying around..or suggestions on what kind of grease is good for this thing to work again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 »</TD></TR><TR><TD CLASS="quote">anyone have a spare lying around..or suggestions on what kind of grease is good for this thing to work again </TD></TR></TABLE>
I think ~50-75% of us have a sticking latch, so it won't close unless you push the latch back to the closed position. Your problem is different, the mechanism is slow.
Lithium grease owns... but you could start with any grease/WD40 to see if lube will even help.
-Chris
-Chris
Re: QT: Troubleshooting with 00 Itr Trunks, Need a part number n name preferrably (b19coupe)
'98 went bad for me. Acura here only charged me $75 for the actuator - and I thought that was expensive
Re: QT: Troubleshooting with 00 Itr Trunks, Need a part number n name preferrably (BudMan)
greased it up today.. n closed it.. now it won't freakn open might have to get a new actuator.. now where is len when you need him.
Re: QT: Troubleshooting with 00 Itr Trunks, Need a part number n name preferrably (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Use the key </TD></TR></TABLE>
trust me i tried that numerous times
Won't work if the actuator is bad. The key is attached to a switch that sends the signal to the actuator.
mine is screwed up too....hopefully acura will cover it.
to open hatch...
turn the key all the way and at the same time pull the latch lever thing.
to open hatch...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
Won't work if the actuator is bad. The key is attached to a switch that sends the signal to the actuator.</TD></TR></TABLE>
yes it will. when you turn it and you think you turned it all the way, turn it a little more until you hear your trunk pop, hold the key there and pull the trunk up. key is the alternative way to open the trunk if the actuator is bad. my friend posted his solution to the same problem in a thread on team integra. let me see if i can find it...
http://www.team-integra.net/fo...earch
his problem was rust. he says your and many other people's problem may be a weak motor resulting from poor lubrication from the factory. his motor was shot as you can see and he replaced it with a used one. works fine.
and yes, it's a very common problem...
hope this helps...
hope this helps...
