trunk latch problems
Old Apr 13, 2005 | 09:40 PM
JumboJoe's Avatar
Default trunk latch problems
I am having problems closing my trunk. When I attempt to close it, the trunk doesnt lock. I can get the trunk flush to the body (looks like its closed ) but cannot get it to 'stick' . Any links or recommendations on how to fix would be appreciated.
Thanks!
Old Apr 13, 2005 | 09:52 PM
Kicker773's Avatar
Default Re: trunk latch problems (JumboJoe)
what year is ur R, if itz an 00 its a common problem. most people open the fluctuator and lube it up or some replace it with a new 01 fluctuator/actuator.
Old Apr 13, 2005 | 10:01 PM
penpen's Avatar
Default Re: trunk latch problems (Kicker773)
hrm, i've had that problem for 2 years now.. . i just jiggle it and it works though, so it's been on the low priority list of things to fix
if it doens't latch at all though... that would be bothersome.
[/useless post]
Old Apr 13, 2005 | 10:08 PM
330R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">what year is ur R, if itz an 00 its a common problem. most people open the fluctuator and lube it up or some replace it with a new 01 fluctuator/actuator. </TD></TR></TABLE>
hmm, I haven't heard of this one before. My hatch closes properly every time. If it's going to fail I wish it would've during the warranty period
Old Apr 14, 2005 | 12:12 AM
dc28012's Avatar
check the latch to see if its in the original position because my latch gets stuck when i push it to the left to open it and the latch stays open so when i try closing it it doesnt close. just push the latch back to the original position to close. i dunno if thats the same problem you have but thats my experience with the trunk latch problem.
Old Apr 14, 2005 | 04:38 AM
Ed 341's Avatar
Yep I have the same problem. I move the switch to the left and then flip it to the right..also I have to slam it kind of hard. Its been like that since I bought it with 45,000 miles so I think its normal..
Old Apr 14, 2005 | 04:47 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JumboJoe &raquo;</TD></TR><TR><TD CLASS="quote">I am having problems closing my trunk. When I attempt to close it, the trunk doesnt lock. I can get the trunk flush to the body (looks like its closed ) but cannot get it to 'stick' . Any links or recommendations on how to fix would be appreciated.
Thanks!</TD></TR></TABLE>
Yeah, like mentioned before, the latch handle itself could be sticky. Jiggle it back and forth to make sure it's all the way to the right.
I have to pull it to the right every time after I open the trunk.
Old Apr 14, 2005 | 04:51 AM
typer_801's Avatar
Default Re: trunk latch problems (itr341)
Hmmm....I've got the opposite problem. Mine doesn't open properly. Closes fine, but when you use the slide button in the hatch (with door unlocked) it won't open. It used to work fine, then all of a sudden stopped. You can open it with key in the rear lock (held fully to the right) while using the rear slide lever, but that's the only way.
Is the fix the same?!?
Old Apr 14, 2005 | 04:52 AM
ebelp's Avatar
Default Re: trunk latch problems (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, like mentioned before, the latch handle itself could be sticky. Jiggle it back and forth to make sure it's all the way to the right.
I have to pull it to the right every time after I open the trunk.</TD></TR></TABLE>
Yep, sometimes my latch will stick in the "open" position so the hatch won't close. I'll do the jiggle of the latch, and it's fine.
Old Apr 14, 2005 | 05:26 AM
Bbasso's Avatar
Default Re: trunk latch problems (ebelp)
I had those problems before but for the past year or two it has not been a problem. I sprayed the latch with WD40 and bingo.
Old Apr 14, 2005 | 07:09 AM
JumboJoe's Avatar
Default Re: trunk latch problems (Bbasso)
Thanks for the response guys! I fixed the problem with a jiggle and some lube
Old Apr 14, 2005 | 07:28 AM
eg4sheezy's Avatar
Yes, wd-40 is your friend, re-apply as needed.
Old Apr 14, 2005 | 09:03 AM
Mires's Avatar
Default Re: trunk latch problems (eg4sheezy)
I have the same problem. Sometimes when I close my hatch the latch will hook but it wont actually close all the way. Even jiggling it and moving it back and forth doesn't work anymore. Im pretty sure it has something to do with the actuator. Ive found that when you open the hatch and you hold the lever to the left for a few seconds then release it works just fine.
Ive just trained myself to do it this way.
Old Apr 14, 2005 | 10:55 AM
RPM's Avatar
RPM
Default Re: trunk latch problems (typer_801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_801 &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm....I've got the opposite problem. Mine doesn't open properly. Closes fine, but when you use the slide button in the hatch (with door unlocked) it won't open. It used to work fine, then all of a sudden stopped. You can open it with key in the rear lock (held fully to the right) while using the rear slide lever, but that's the only way.
Is the fix the same?!?</TD></TR></TABLE>
I have this exact same problem.
Old Apr 14, 2005 | 11:09 AM
totsie7944's Avatar
I have an 00, mine sometimes gets caught in the open position so I have to push it over and then close it kinda hard. But mine has never NOT closen before so I really don;t worry about it. Try lubing it some and if it still doesn't latch properly I would suggest gettign a 01 latch.
Old Apr 14, 2005 | 06:55 PM
Mires's Avatar
Default Re: trunk latch problems (totsie7944)
Mine is a 2001.
Old Apr 14, 2005 | 07:08 PM
Kenso's Avatar
HT White Ops
Default Re: trunk latch problems (RPM)
Bad actuator. I've replaced a few to correct this problem.
Old Apr 14, 2005 | 07:16 PM
Kicker773's Avatar
Default Re: trunk latch problems (Kenso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kenso &raquo;</TD></TR><TR><TD CLASS="quote">Bad actuator. I've replaced a few to correct this problem.</TD></TR></TABLE>
here are more comments on the issue
https://honda-tech.com/zerothread?id=987149
lawnrider
May 11, 2012 10:32 PM
lawnrider
Mar 22, 2011 09:22 PM
gaaray2k
Acura TSX
May 19, 2009 04:31 AM
kensan
Oct 20, 2005 10:45 AM
Kicker773
Oct 10, 2004 04:42 PM
