Peculiar clutch pedal behavior
I've noticed something strange the last couple days: when I engage the clutch, sometimes it seems to start engaging much closer to the floor than normal. It isn't enough to make me jerk the shift or anything, but it's been enough to make me wonder if something is wrong. It also doesn't happen every time, but it's been often enough over the last couple days that I don't think it's a fluke.
I'm planning to bleed the clutch tomorrow to see if that fixes it. Anything else I should check while I'm at it? TIA
could be the master, or slave leaking. I wouldn't ignore it, you don't want to be shifting at high rpm with the clutch not fully disengaged, unless you feel like replacing synchros...
I would also change fluid and make sure it's bled really well.
Re: Peculiar clutch pedal behavior (Agent Smith)
When I had this problem it turned out to be the clutch slave cylinder. Check your fluid, if it is low then you probably have a leak either at the master or slave. Also, my friend had this problem. He just adjusted his and it went away. His clutch only has about 5k miles on it.
Re: (Boondock Saint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint »</TD></TR><TR><TD CLASS="quote">could be the master, or slave leaking. I wouldn't ignore it, you don't want to be shifting at high rpm with the clutch not fully disengaged, unless you feel like replacing synchros...
I would also change fluid and make sure it's bled really well.</TD></TR></TABLE>
Yep, it's the master or slave. Hopefully the slave as it's a hell of a lot easier to change out.. well it produces less back pain anyways
If it's the master, take the drivers seat out when you swap it out.
mine did the same thing right before the clutch master cylinder went out. bad thing was that i didnt get around to fixing it right away.... i got stranded trying to cross a four way stop and almost got screwed because of that..
u got plenty of fluid in it?
s13hero
14
11-21-2010 04:57 PM
