ok, need some more help with the header
it seems like i have all the bolts out but the header still wont come out... this is what i have out so far...
what am i missing?
[Modified by FusionITR, 3:53 PM 4/13/2002]
what am i missing?
Re: ok, need some more help with the header (i 4)
kick it
Take your time, drop the cat., should come off pretty easily.
New User
Re: ok, need some more help with the header (csufweed)
Nooo...you don't need to remove the fan. It's unneccessary (I spelled that wrong), but it will help. You might need to remove the plastic underlining though that gets in the way of the header. Oh yah, make sure you get the bolts that are along the A-Pipe near the radiator (which I know, is a very broad area). Then for the O2 sensors, you can try an 7/8" Wrench, or they do have special sockets just for O2 sensors. Have fun......
New User
Re: ok, need some more help with the header (Waxing "The Carrot")
Wow, nice image. Basically a shot of the OEM Brackets.....let me find something else......
Re: ok, need some more help with the header (FusionITR)
remove the plastic splash shield from under the header for elbow room, and loosen the OE rear support bracket if needed... then whack it if it is still heat bonded to the gasket... I use my 5lb fist mallet if my rubber one is out of reach...
New User
Re: ok, need some more help with the header (Zeus)
There's another one coming up......this is the first (Hopefully they work...).
[Modified by Waxing "The Carrot", 1:55 AM 4/14/2002]
New User
I can not post a F'n picture!! ****, I just tried to setup an account through imagestation and I uploaded the pictures....but.....now they won't work. I quit.....basically I was going to upload pictures of the Helm's manual. ****!
Re: ok, need some more help with the header (tecnic1)
damn...finally someone whos valve cover looks worse then mine
take off the cat. if it is still stuck, just take a rubber mallet and give it a wack!!! when in doubt use force!!
[Modified by cali-r, 5:16 AM 4/14/2002]
