Getting header out
Old Aug 31, 2003 | 01:03 PM
JoshRambo's Avatar
Default Getting header out
So i am removing my JDM header from the car. Got every thing unbolted and the damn thing won't come out.
What is the trick to getting a one peice header out of the enging bay.
Old Aug 31, 2003 | 01:19 PM
jdmspoonitr's Avatar
Default Re: Getting header out (Gravity)
If you are looking at the header straight on (standing on front of headlights), jack up the car. Then you will need to angle the left side of the header down first before you drop the right side. It will only slide out one way.
Old Aug 31, 2003 | 06:43 PM
Padawan's Avatar
Darth ModerVader
Unbolting the fans and moving the AC lines can sometimes help.
Old Aug 31, 2003 | 06:48 PM
PM-Performance's Avatar
Default Re: Getting header out (Padawan)
just drop it down and finaglew it, it swill come with patience
Old Aug 31, 2003 | 06:54 PM
B2FiNiTY's Avatar
You can unbolt 3 of the 4 bolts on the a/c condensor allowing you to swing it and clear enough room to drop the header easily.
Old Sep 1, 2003 | 10:00 AM
JoshRambo's Avatar
Default Re: Getting header out (B2FiNiTY)
man me being an idiot thought i could get it out with out moving the splash gaurd on the bottom. I figured it would push right past.
Well I moved the guard and the thing slipped right out. got it out and other header on in under an hour.
Old Sep 1, 2003 | 10:56 AM
len's Avatar
len
Plasma Cutter?
Wiggle it back and fourth. Helps to have your radiator fans off.
Old Sep 1, 2003 | 01:34 PM
Misfit's Avatar
Default Re: Getting header out (len)
It isn't that hard to do.. i did it myself with some patience and thought process.
RedneckRicer
Apr 3, 2008 12:05 PM
sikciv666
Jun 1, 2006 07:30 PM
slow91crx
Jun 3, 2005 04:54 AM
