Need sparkplug #
Old Nov 29, 2002 | 10:42 AM
Big Phat R's Avatar
Default Need sparkplug #
I'm looking for the SKU or code for the NGK plugs that are one temperature range cooler than stock for a B18C5.
Anyone??
Old Nov 29, 2002 | 11:01 AM
Junior_r's Avatar
Default Re: Need sparkplug # (Big Phat R)
This one? PFR7G-11 honda part # 98079-5714H
Old Nov 29, 2002 | 11:02 AM
skafia's Avatar
25 Year Member
Anyone??
One temperature range cooler than stock?
Old Nov 29, 2002 | 11:06 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Need sparkplug # (skafia)
Doesnt the number in the middle dictate temp range? So like a PFR6 G-11 would be one step colder than a PFR7G-11?
ZygSpeed's Avatar
The stock plug is either an NGK PFR6G-11 or a Denso PK20PR-L11.
I'm pretty sure that the last number (11) is indicative of the heat range, and that the step one colder would be something 09,
two steps colder would be an 07 (for turbos). HTH Ed
I could be wrong ...
[Modified by Zygspeed, 3:07 PM 11/29/2002]
Old Nov 29, 2002 | 11:08 AM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: Need sparkplug # (Zygspeed)
Yes, im right. the last number is the gap, middle number is heat range.
Old Nov 29, 2002 | 11:10 AM
Junior_r's Avatar
the last number indicates the gap and the middle number indicates the heat range
HOTTER
PFR5G-11
PFR6G-11
PFR7G-11
COLDER
[Modified by Junior R, 2:33 PM 11/29/2002]
Old Nov 29, 2002 | 12:18 PM
Asahi's Avatar
Default Re: Need sparkplug # (Junior R)
HOTTER
PFR5G-11
PFR6G-11
PFR7G-11
COLDER
Yup he is right. Kinda like a higher # FD = lower top speed. Somewhat counter intuitive.
Old Nov 29, 2002 | 12:27 PM
Teepo's Avatar
Default Re: Need sparkplug # (Asahi)
NGK #2380 #7 platinums
Old Nov 29, 2002 | 12:45 PM
rambler's Avatar
New User
$11.92 from hparts.com
ouch!
Old Nov 29, 2002 | 01:08 PM
TypeR76's Avatar
Default Re: Need sparkplug # (rambler)
the last two numbers are gap size 1.1mm
Old Nov 29, 2002 | 01:16 PM
GiFF's Avatar
for denso 20 is the heat range, you would want ik22 or ik24 or denso...
ik22 = 7 heat range, and ik24 = 8 heat range
[Modified by G i DouBLe F, 2:16 PM 11/29/2002]
Old Nov 29, 2002 | 01:57 PM
TodaSi's Avatar
Default Re: Need sparkplug # (G i DouBLe F)
Go for NGK Iridium
BKR6EIX-11 Stock # 3764 looks promising (although it's stock heat range). It's a little over $7 a plug and has a nice small electrode to help flame propagation.
They are available here
http://www.clubplug.net/retail_iridium_ngk.html
I don't see anything in an NGK 7 range plug.
Old Nov 29, 2002 | 03:55 PM
Big Phat R's Avatar
Default Re: Need sparkplug # (TodaSi)
I have the Spoon plugs (Iridiums) right now - but still have a lot of pre-ignition on 94 octane at low rpm load conditions. High rpm is fine (no pinging).
Old Nov 29, 2002 | 04:19 PM
sgT's Avatar
sgT
whats your base timing? maybe be better to im me for specific questinos
as internet access is limited.
Old Nov 29, 2002 | 04:37 PM
LeftCorner's Avatar
Spark plug breakdown: http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
Old Nov 29, 2002 | 06:59 PM
IN VTEC's Avatar
Default Re: Need sparkplug # (TypeR76)
You want a 13 (1.3mm) gap. It's not a real big deal if you don't get the 13's...just saves you the hassle.
Old Nov 29, 2002 | 09:30 PM
Big Phat R's Avatar
Default Re: Need sparkplug # (sgT)
Timing is stock. Fuel pressure is about 46-50 (vacuum hose off) - but ECU (Hondata) was initially tuned at stock pressure (43 psi I think). Car ran well - but when I did some track days out of my area (and was forced to use 92 octane) I bumped up the fuel pressure.
The Hondata was tuned in-car using a wide band - I only asked for stoichiometric across the rpm range - I was really only interested in getting the fuel map cleaned up. Before I do some serious dyno tuning though - I want to get rid of this pre-ignition issue.
Thank goodness for the post on the EVAP purge solenoid - my swinging idle was getting on my nerves. Since I've disconnected the solenoid - the car idles like butta.
Other than plugs - what are the causes of pre-ignition? Should I retard my timing some more? Use a smaller gap on my plugs? Get the head ported more (still basically stock) - I have about 12:1 compression with the Endyn 81.5mm pistons I'm using....
Old Nov 29, 2002 | 11:00 PM
Kengs's Avatar
NGK Iriway (0.6mm electrode) comes in a 7 (and 8) heatrange.
The 7 is BKR-E (Stock No. 4145); I would think AJR would have some in stock?
Old Nov 30, 2002 | 02:35 AM
RagingAngel's Avatar
I dunno how you got the hondata tuned for stoich...but my guess even stoich for WOT, since you have pre-ig issues?
If thas the case then it's way too lean.... on slightly bumped CR I'm running closer to high 12s on the AF when I'm going WOT. The car just seems to like more gas (to a certain degree)
Plus the added fuel keeps things cool. Maybe I'm interpreting your post incorrectly, but I'd have your tuner put some more fuel in at WOT.... esp. with your "heady" CR
yeegsr
14
Oct 11, 2004 12:06 AM
ykracing
Sep 9, 2004 03:55 PM
ITRFetish2000
May 29, 2004 05:00 PM
R-1303
Jan 29, 2003 10:02 PM
SlowB16
Apr 10, 2002 09:15 AM
