spark plugs?
Old Jan 29, 2003 | 06:06 PM
R-1303's Avatar
Default spark plugs?
ok..drag recommends ngk bcpr 7es -11..but can i use the ngk bkr7es?? and what the hell is the -11 for?..does it have to be -11?? i did a search and haven't found the answer to these questions..thanks
For:2000 ITR turbo
Old Jan 29, 2003 | 06:31 PM
ekb18c's Avatar
Default Re: spark plugs? (R-1303)
both plugs are fine. bkr and bcp re both fine.
http://www.ngk.com for some research.
HTH
Old Jan 29, 2003 | 06:48 PM
mos's Avatar
mos
Default Re: spark plugs? (ekb18c)
Both plugs are the basically the same. The 11 just means the gap is pre set to 1.1 mm but you should check and gap them anyways, so you can go with bcpr7es also.
Old Jan 29, 2003 | 10:02 PM
R-1303's Avatar
Default Re: spark plugs? (mos)
oh ok..thanks! now i now what the -11..and thanks i did go to ngk website. thanks people!
crazybeanery0
Sep 23, 2008 05:52 PM
sir222
Sep 16, 2006 08:44 AM
jBj
May 13, 2005 02:16 PM
brownman72000
Oct 10, 2002 03:05 PM
ceemarun
Jul 3, 2002 01:14 AM
