Need Help with Check Engine LIght
Old Aug 13, 2007 | 08:40 PM
DC2 R guy's Avatar
Default Need Help with Check Engine LIght
Modified by DC2 R guy at 3:28 PM 9/18/2007
Old Aug 14, 2007 | 09:45 AM
itr1244's Avatar
Default Re: Need Help with Check Engine LIght (DC2 R guy)
try to reset the ecu first and tell me if it goes away
Old Aug 14, 2007 | 04:10 PM
DC2 R guy's Avatar
Default Re: Need Help with Check Engine LIght (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">try to reset the ecu first and tell me if it goes away</TD></TR></TABLE>
i did but it comes back on
Old Aug 14, 2007 | 05:45 PM
DC2 R guy's Avatar
HELP!!
Old Aug 14, 2007 | 07:22 PM
Biloxi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 R guy &raquo;</TD></TR><TR><TD CLASS="quote">I have a V-tec pressure valve and have no idea how to fix it. Do I take out the V-tec solenoid and clean the screen? Please help. Sometimes when I drive a little hard and stop, then take off normally, my car boggs and I feel like I lose a lot of power. Then I floor it and it won't go no where and I turn off the car to a complete stop and turn it right back on then the car is fine. Please help me fix my Vtec pressure valves. Show me some love ITR members! Thanks.</TD></TR></TABLE>
get a new one PRESSURE VALVE!
Old Aug 15, 2007 | 12:38 AM
HSPxNick's Avatar
Default Re: Need Help with Check Engine LIght (Biloxi)
have u try jumping the green harness for a trouble code?
Old Aug 29, 2007 | 11:09 PM
DC2 R guy's Avatar
Default Re: Need Help with Check Engine LIght (erasa510)
YES I DID
Old Aug 30, 2007 | 05:47 AM
exies's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 R guy &raquo;</TD></TR><TR><TD CLASS="quote">YES I DID</TD></TR></TABLE>
It would be helpful if we knew what the code was.
Old Aug 30, 2007 | 07:31 AM
DC2 R guy's Avatar
Default Re: Need Help with Check Engine LIght (exies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exies &raquo;</TD></TR><TR><TD CLASS="quote">
It would be helpful if we knew what the code was.</TD></TR></TABLE>
22 V-tec pressure
Old Aug 30, 2007 | 09:59 AM
tmanrose2007's Avatar
I had the same problem, I cleaned out the screen, I reset the ECU multiple times, but in the end it was the wire going into my ECU. The pin came out so check your wires to your ECU.
Old Aug 30, 2007 | 12:30 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 R guy &raquo;</TD></TR><TR><TD CLASS="quote">22 V-tec pressure</TD></TR></TABLE>
Last time I looked in the service manual, I thought it referred to a diagnostic procedure for each CEL code.
Look in your service manual...
Old Aug 30, 2007 | 03:25 PM
grjp1988's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 R guy &raquo;</TD></TR><TR><TD CLASS="quote">HELP!!</TD></TR></TABLE>
NO, THERE'S TO MUCH VTEC YO!
on a seriouse note check your wires in your ecu.
Old Aug 30, 2007 | 04:47 PM
all-mtr-teg's Avatar
do you have enough oil?
Old Aug 31, 2007 | 02:36 PM
DC2 R guy's Avatar
Default Re: Need Help with Check Engine LIght (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">do you have enough oil?</TD></TR></TABLE>
yes i do
bigdonnyboi
Mar 7, 2007 05:18 PM
95GSRDC2
May 23, 2006 05:46 PM
xtreme-customz
18
Dec 1, 2005 07:51 PM
Sick'Lude
Aug 3, 2005 12:33 PM
skafia
Jan 13, 2004 07:10 AM
