Need help asap cps lost signal code 9 ?
Old 04-25-2019, 06:42 PM
00civbus's Avatar
Default Need help asap cps lost signal code 9 ?
Hey just put my poor man type r (b18c bottom end type r head ) together and in my 00 civic and I have the code 9 for lost singal to my cylinder position sensor that's in the disruptor? Wanting to know if anyone else has ran it to this motor will only crank over wont start has fuel when I first start it up. Then it stops i think that's because of it doesn't know when to inject it. And it dose have spark. I'm runing s300 and also did a abs delete to it as well but I kept the fuze box for it hooked up . Just mentioning that so it's not something like a shared ground / power cause my issue. Please help I would like to figure this out
Old 04-28-2019, 07:27 PM
wunfstgsr's Avatar
Default Re: Need help asap cps lost signal code 9 ?
Well you have a OBD2B chassis. What engine harness and ECU harness do you have? You should have a OBD2B to OBD1 ecu conversion harness to start with.
type r em1
06-13-2019 05:47 PM
ZombiePharoh
Engine Management and Tuning
03-29-2012 02:12 PM
run for cover
12-18-2011 01:02 PM
Quick Reply: Need help asap cps lost signal code 9 ?
