NEed help.
Old Sep 11, 2007 | 10:50 AM
dx on the move's Avatar
Default NEed help.
01 Type R stock everything. Car idles rough has CEL code for secondary o2, changed plugs they were carbon filled. Put new ones in and withing a week they were black again. Some one told me that the secondary o2 doesnt affect performance, so the o2 wouldnt make the car run rich and act wierd. Yesterday i started the car and it turn off within a minute, then everytime that i would try to start the car it would turn off immediately. I tried for hours to figure it out. I left it for about 2 hrs, then i tried again and after thge 4th time it turned on. Anyone knows what could be the problem?
Old Sep 11, 2007 | 11:21 AM
ZygSpeed's Avatar
Default Re: NEed help. (dx on the move)
Lots of bent valves??
Have you done a compression test?
Old Sep 11, 2007 | 11:23 AM
GO-FIGHT-KILL's Avatar
^ My thoughts.
Old Sep 11, 2007 | 01:20 PM
nope havent done a compression test. This should be done on a cold motor and the numbers should be around?
Old Sep 11, 2007 | 02:35 PM
would the secondary o2 cause the car to be acting like this?
Old Sep 11, 2007 | 07:03 PM
Default Re: (dx on the move)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dx on the move &raquo;</TD></TR><TR><TD CLASS="quote">nope havent done a compression test. This should be done on a cold motor and the numbers should be around?</TD></TR></TABLE>
Warm engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dx on the move &raquo;</TD></TR><TR><TD CLASS="quote">would the secondary o2 cause the car to be acting like this?</TD></TR></TABLE>
No.
Old Sep 12, 2007 | 06:54 AM
citrus3000psi's Avatar
Theres something causing the car to run rich. You have prolly fouled out your 02 sensor from the richness. I would agree, do a comp test, its cheap and easy.
Old Sep 14, 2007 | 12:26 PM
compression test turned out fine what else could it be?
Old Sep 14, 2007 | 12:28 PM
How's your A/F Ratio at idle?
Old Sep 14, 2007 | 12:56 PM
dont know dont have tools to read that at my disposal
Old Sep 14, 2007 | 01:02 PM
anyone else ?
Old Sep 16, 2007 | 11:57 AM
gurus where are u ?
Old Sep 16, 2007 | 11:58 AM
It's really broad man... Is your maintanence up to spec? i.e. Distributor cap/button/plugs/wires/fuel filter.
Modified by GO-FIGHT-KILL at 1:25 PM 9/16/2007
Old Sep 16, 2007 | 12:02 PM
BMaDOHC's Avatar
Default Re: (GO-FIGHT-KILL)
could also be your ignition switch with the car starting and dying over and over. next time it starts and is idling, grab your key and move it around while the cars running, if it stalls you need an ignition switch
or, you flooded the **** out of it and it wouldn't start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">It's really broad man... Is your maintence up to spec? i.e. Distributor cap/button/plugs/wires/fuel filter.</TD></TR></TABLE>
Old Sep 18, 2007 | 06:30 PM
ok lets start over. Car will start and then shut right off. Checked the fuel pump it goes on but no fuel goes to the rail.
Old Sep 19, 2007 | 01:23 PM
help help
Old Sep 19, 2007 | 03:56 PM
Dave-ROR's Avatar
I assume no CELs? Valve's adjusted to spec? timing set correctly? timing belt didn't skip a tooth? confirmed spark at all four plugs?
need more info on what you've done so far. What were the comp numbers btw?
Old Sep 25, 2007 | 07:38 PM
k finally got parts for dizzy, instead of waiting to find a whole one. Car started, tomorrow i will test drive and post. Thanks to all for their help.
alexm
Sep 10, 2008 09:59 PM
iRIDEdumped
Jul 28, 2005 02:35 PM
strizzy
Dec 27, 2003 02:57 PM
madhatter07
Aug 9, 2003 06:30 AM
