map sensor question
Old Dec 24, 2003 | 09:24 PM
JjuuN R's Avatar
Default map sensor question
sorry guys this is so
but this afternoon i was going through my "put my car back together" routine and forgot to plug the map sensor in and started my car
anyway i quickly remembered right after i turned it over and shut it off, i went to plug it in and now it's throwing me a CEL. anyone other then my stupid self end up doing this and end with a CEL? tried resetting the ecu thinking it's nothing but that's a no-go.
i'll check out the code in the morning, untill then can anyone enlighten me?
Old Dec 24, 2003 | 09:35 PM
R6Boy69's Avatar
Default Re: map sensor question (JUN.R)
i would say just try to reset the ecu again... how did you do it last time?
Old Dec 24, 2003 | 10:12 PM
JjuuN R's Avatar
how did i do what last time?
Old Dec 25, 2003 | 12:11 AM
NXSpoon's Avatar
Default Re: (JUN.R)
I think he means "How did you reset the ECU last time??"
Is the CEL for a MAP sensor problem??
Old Dec 25, 2003 | 01:44 AM
JjuuN R's Avatar
not sure yet, i'll check it out in the morning. i removed the ecu fuse and put it back in to answer your question if that in fact is your question
Old Dec 25, 2003 | 02:17 AM
NXSpoon's Avatar
Default Re: (JUN.R)
I did something similar with the IAT sensor once. Started the car with it unplugged.
Turned car off, reconnected sensor, disconnected battery, had a smoke, reconnected battery, and no more CEL.
Maybe the MAP sensor is different. Good luck.
Old Dec 25, 2003 | 02:56 AM
JjuuN R's Avatar
Default Re: map sensor question (crXBoy69)
thanks for the info
hondalove414
Mar 20, 2011 08:11 AM
bopbop93030
Jan 6, 2009 01:50 PM
msinsky14
Nov 25, 2008 05:57 PM
88crxdxfastwhip
Mar 13, 2006 06:35 PM
kell211
Oct 7, 2003 05:39 PM
