higher comp...
Old Oct 20, 2002 | 01:21 PM
96tegsr's Avatar
Default higher comp...
Well, i posted this post on the integra forum but there wasnt any help watsoever so i thought i'd post it here. I opened up my engine today to replace the piston ring due to leaks on mostly all the cylinder and it would not pass smog. I am replaceing my piston rings, clutch and possibly valves. Since the engine is already out, i would like to raise my compression to about 11:1 ( since Im planing on adding Sunk 2 IM and stage 1 cams later on after the smog). WOULD RAISING THE COMPRESSION THAT HIGH AFFECT SMOG? I think that it wont but i just want to verify it
Old Oct 21, 2002 | 02:12 AM
96tegsr's Avatar
Default Re: higher comp... (ridge racer 2)
wow.. i never knew that. Can anyone else verify this. I will probably go with b16 pistons to raise it to about 11:1
Old Oct 21, 2002 | 08:36 AM
sgT's Avatar
sgT
Default Re: higher comp... (96tegsr)
b16a pistons will raise your CR to about 11.5:1
if you want 11.0 or close to it, then your best bet is US ITR pistons.
Kafelatte
Apr 7, 2007 04:06 PM
sir3n
Dec 16, 2003 12:53 PM
Luserkid
Aug 3, 2003 03:30 PM
96tegsr
Oct 20, 2002 12:30 AM
underrated99si
Feb 22, 2002 11:51 AM
