Heating issues .. help !!
Old May 26, 2007 | 03:18 PM
iperez's Avatar
Default Heating issues .. help !!
2001 ITR with a ton of mods. Specific cooling mods: Meziere electric water pump, Mugen thermoswitch.
The car has been working fine for the last two years since I installed the electric water pump. However, a couple of days ago one of the fans has stopped working. When I am cruising the higway everything works fine but when I am in everyday traffic or just standing still, the car heats up to just over the halfway mark on the dash gauge and my A/C stops cooling. Once I start moving again, everything comes back to normal.
I know the fans work because I can hook up power directly and the start right up. So the problem is probably in a sensor or something. I am digging for my oem thermoswitch to install that and discard that as a possible problem. What else can I look into ??
Here's a pic of the evidence.. notice the fan on the right NOT turning.
Old May 26, 2007 | 04:14 PM
Arsenal's Avatar
Default Re: Heating issues .. help !! (iperez)
Had the same thing last week. Was the water sensor located on the thermostat. Large nut, should be able to see it easily, has a connecter coming off of it.
Basically tells the fand to turn or not, but if it fails they won't kick in.
$30 at Honda (at cost)
Old May 26, 2007 | 04:33 PM
iperez's Avatar
Yup .. that's the thermoswitch. I've had a hard time finding my original one which I replaced with a Mugen part. At least you give me hope that once I find this darned thing I'll have my problem solved.. Any other suggestions ??
Old May 26, 2007 | 04:41 PM
fourcsan's Avatar
* B A N N E D *
replace that sensor he was talking about, but first make sure your fan fuse isnt blown. i had that problem. checked my whole wiring etc. and it was my fuse (GRR)
Old May 26, 2007 | 05:06 PM
iperez's Avatar
I'll chek the fuse .. BTW, wouldn't a bad thermoswitch affect BOTH fans, not just one ??
Modified by iperez at 3:06 AM 5/27/2007
Old May 27, 2007 | 10:01 AM
iperez's Avatar
Default Re: (iperez)
Update: You guys were right on BOTH accounts. The thermoswitch and the fuse were both shot. I replaced both parts but my fans are still not coming on and my A/C is not cooling. What's next ??
Old May 27, 2007 | 11:00 AM
fourcsan's Avatar
* B A N N E D *
is the fuse blown again? probably grounding out somewhere.
raider1qaz
12
Aug 19, 2013 07:39 PM
90gs
Mar 10, 2009 07:40 PM
dc2415
Jul 1, 2007 08:51 AM
fdjizm
Mar 2, 2007 08:03 PM
CA6VTEC
Aug 26, 2004 06:37 PM
