Slight Overheating Problem.
Old Aug 26, 2004 | 06:32 PM
CA6VTEC's Avatar
Default Slight Overheating Problem.
<FONT COLOR="royalblue"> When on idle the temp gauge passes the halfway mark and then turns on. Once the car was completely cold ( 24hrs) I removed the rad cap and turned it on. The coolant kept slighty spraying out. When the car is in motion, the temp needle never reaches the halfway point. Also when it starts overheating and start moving, the needles goes back down. any ideas? Water pump is new ( OEM)</FONT>
Old Aug 26, 2004 | 06:37 PM
VTECrazed's Avatar
Default Re: Slight Overheating Problem. (CA6VTEC)
Well if there is no air in your radiator, and water pump is new and its overheating not moving. But when you do move it goes down. Sounds to me like a new thermostat is needed there, or it could be a faulty water pump.
supaf1y
Jul 9, 2009 06:08 PM
nonvtec92
14
Nov 28, 2008 04:50 PM
richboi
Mar 25, 2006 04:41 PM
sherman19
Jan 30, 2003 05:36 AM
sackdz
Nov 27, 2001 03:30 PM
