good setup for now?
Old Sep 14, 2002 | 11:23 AM
YellowR2000x2's Avatar
Default good setup for now?
so after looking at the block and seeing the HUGE crack in the back..this is what ive decided to do...
import builders 2l built block
portflow work on the head for better flow and to increase the comb. chamber to match the block.
exedy clutch and fidanza flywheel.
what kind of power with just that, plus 2.5 exhaust and AEM CAI, would i be looking at? obviously ill add more as cash permits, add a toda header and carsound cat to that package in about a month or so. also i was wondering..when going to 2l, is there anything else i need to change out so i dont run too lean? bigger injectors? fuel pump? i dont want to starve my car! any suggestions would be helpful!
Old Sep 14, 2002 | 11:25 AM
Reid's Avatar
Global Moderator
Default Re: good setup for now? (YellowR2000x2)
Sounds good.
Keep all other parts the same if you're still using stock cams.
Old Sep 14, 2002 | 11:32 AM
Default Re: good setup for now? (Reid)
kewl, thanks for all the help so far reid, guess we kinda got off to a bad start when all of this happened to me, but thanks for all the input you've given me so far, its really helped me out alot. i was just scared that going to 2l was going to wreak havoc on my A/F ratio or just amount of fuel id be getting. anyone know what kind of power ill have with this setup? close to 200whp? more?
Old Sep 14, 2002 | 11:36 AM
Reid's Avatar
Global Moderator
Whoops, I wasn't thinking.
I'm not familiar with the specs of Jeff's block.
Old Sep 14, 2002 | 11:39 AM
in regards to the power, or the fuel? hehe
fuel?=important
power?=just to get me all happy again about getting it
Old Sep 14, 2002 | 11:41 AM
Rob :190:'s Avatar
get a VAFC or some kind of fuel management and the A/F ratio will be fine, i'm sure others have done it...
Old Sep 14, 2002 | 11:44 AM
Reid's Avatar
Global Moderator
What are the specs of the block you're getting from Jeff?
Like Rob said, light tuning with a V-AFC should be more than enough.
Old Sep 14, 2002 | 11:47 AM
kewl, sounds good, heres the specs:
IB 2 liter All Motor "Dominator" Block. JE custom pistons, eagle/probe rods, balanced, new bearings, new oil pump, vtec water pump, bored, honed, assembled, deck checked, polished and balanced crank. new rear main seal, new oil pan gasket, Oil line tapped, complete.. $3050 Shipped. (that includes the block).
according to the website, jeff said comp ratio should be around 12.1 or so.
Old Sep 14, 2002 | 12:09 PM
Rob :190:'s Avatar
damn, a 2.0 ITR motor at 12.1....I am jealous
rob- who thinks thats how ITRs should have come from Honda
Old Sep 14, 2002 | 12:36 PM
Default Re: good setup for now? ( Rob)
so, where do you guys recommend getting my head work done at? portflow, dpr, etc..? and why? im thinking of going with portflow, good price and looks like good work.
Old Sep 14, 2002 | 12:37 PM
Reid's Avatar
Global Moderator
Portflow.
Tom is a cool guy and he does good work for a fair price.
Old Sep 14, 2002 | 12:42 PM
also it seems that 2 or 3 of my valves are bent, they hit the piston, should i just replace them with stock valves, or go with somthing better? would i have to get new guides if i went with like ferrea? just wondering
Old Sep 14, 2002 | 12:44 PM
Reid's Avatar
Global Moderator
Stock valves are fine for N/A applications.
Old Sep 14, 2002 | 12:47 PM
thanks for all the help!!
eg:R
Apr 19, 2014 08:56 AM
chaokongz
Jul 4, 2009 01:06 PM
JDMBrosDude
19
Aug 29, 2007 08:37 AM
a1320addict
Nov 30, 2005 03:02 PM
IMPORTant Si
Jan 4, 2005 09:24 PM
