Function7 LCA Install
Old Oct 22, 2005 | 07:13 AM
RaVAGE00's Avatar
New User
Default Function7 LCA Install
I am about to install a set of Function7 LCA's on the R and I had some questions. I have attached a pic, I purchased new bolts however they seem not to fit (see pic). As well, on the stock R LCA's a nut is designed into the LCA, where as on the Function7 units, this is missing (see pic).
Thanks in advance.
Old Oct 22, 2005 | 10:38 AM
uNF$@#!'s Avatar
Default Re: Function7 LCA Install (RaVAGE00)
so ask them where the bolt is.
Old Oct 22, 2005 | 11:06 AM
IN VTEC's Avatar
Use a stainless flange nut to replace the lacking ones. I had the weld nut removed on my ITR LCA's to make it easier to remove/install that bolt.
As for the bolt size, don't the Function7 LCA's use a spherical bearing? Maybe you need an equivalently-sized imperical bolt instead of metric 10mm bolts. THat would be 3/8" (a hair smaller than 10mm).
Old Oct 22, 2005 | 11:16 AM
drjoe's Avatar
you need to get longer bolts for the shock and sway bar attachment, you can prob source out some nuts from the front suspension ie front control arm.........the bolts do fit, you just have to work them in ...or you could get the 3/8's like the last guy said, but i trust oem bolts more.
Old Oct 22, 2005 | 11:23 AM
Booker's Avatar
Banned Duplicate Account
https://honda-tech.com/zerothread?id=1161837 maybe there is help here?
Old Oct 22, 2005 | 05:40 PM
RaVAGE00's Avatar
New User
Default Re: (drjoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjoe &raquo;</TD></TR><TR><TD CLASS="quote">you need to get longer bolts for the shock and sway bar attachment, you can prob source out some nuts from the front suspension ie front control arm.........the bolts do fit, you just have to work them in ...or you could get the 3/8's like the last guy said, but i trust oem bolts more.</TD></TR></TABLE>
I rather use OEM hardware so therefore, how can I get longer bolts, they are only available in one size.
Old Oct 23, 2005 | 12:13 PM
Dr Pooface's Avatar
Default Re: (RaVAGE00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaVAGE00 &raquo;</TD></TR><TR><TD CLASS="quote">I rather use OEM hardware so therefore, how can I get longer bolts, they are only available in one size.</TD></TR></TABLE>
Just find a local fastener supplier and see if they have the size bolt you need in a grade 8.
Old Oct 23, 2005 | 12:41 PM
drjoe's Avatar
Default Re: (Dr Pooface)
1. the only bolts that are too short are the lca to shock and lca to swaybar
2. the bolt connecting the rear arm to the brakes is the longest
3. use the above bolt and connect the lca to shock
4. you will have an unused lca to shock
5. use the above bolt to connect the lca to sway bar.
6. use nuts from the front lca ( they are not welded in) for the sway bar and shock connection
your good to go
Old Oct 24, 2005 | 03:48 AM
Black R's Avatar
25 Year Member
If you have to go through all that trouble to replace nuts and bolts, you might as well make sure you buy some locking nuts with the nylon inside - that way you won't have to worry about them coming loose due to vibration over time.....
Old Oct 24, 2005 | 06:16 AM
RaVAGE00's Avatar
New User
Default Re: (drjoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjoe &raquo;</TD></TR><TR><TD CLASS="quote">1. the only bolts that are too short are the lca to shock and lca to swaybar
your good to go
I have no idea what the heck you just said....
HotCheetos
10
Dec 11, 2010 09:07 PM
IAcivicEK
Jul 28, 2007 08:26 AM
ZipTieGUy
Feb 27, 2006 06:08 PM
BLUE EH3
Suspension & Brakes
14
Jun 7, 2005 05:01 AM
_noname_
Aug 20, 2001 01:16 PM
