car keeps idiling fast and slow
Old 02-15-2007, 01:55 PM
john457's Avatar
Default car keeps idiling fast and slow
my 92 civic runs rough and keeps idiling fast and slow and sometimes hesetates for a second before starting. I already changed the cap rotor and coils last year. Any ideas as to what is causing this?
Old 02-15-2007, 01:57 PM
CivicGSRsi's Avatar
Default Re: car keeps idiling fast and slow (john457)
Bad battery.... at least check it out... how fast is the idle jumpin like what from what?
Old 02-15-2007, 02:00 PM
NoEx00's Avatar
my cousin ride was runnin like that...idk maybe check out the sensors...
HCJDM1's Avatar
Default Re: car keeps idiling fast and slow (CivicGSRsi)
iacv ... maybe ... im still fixing that same problem on my other car ... just need spmespark plugs and the car will run again ...
Old 02-15-2007, 02:04 PM
philosofy1's Avatar
Default Re: car keeps idiling fast and slow (HCJDM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 &raquo;</TD></TR><TR><TD CLASS="quote">iacv ... maybe ... im still fixing that same problem on my other car ... just need spmespark plugs and the car will run again ...</TD></TR></TABLE>
that or the pcv valve, the one thing many over loko but can also cause this problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicGSRsi &raquo;</TD></TR><TR><TD CLASS="quote">Bad battery.... at least check it out... how fast is the idle jumpin like what from what?</TD></TR></TABLE>
definately not the battery.
Old 02-15-2007, 02:07 PM
CivicGSRsi's Avatar
I tellin u if its taking for ever to start its the battery and the idle is just from the AC being on
Old 02-15-2007, 02:10 PM
HCJDM1's Avatar
Default Re: car keeps idiling fast and slow (philosofy1)
cant it also be the map sensor ?
Old 02-15-2007, 02:18 PM
john457's Avatar
someone told me it could be the intake idil valve but can you tell me if there is an injection sensor ine the engine, and where is the map sensor?
Old 02-15-2007, 02:23 PM
na+b18c_hatch's Avatar
def. an idle air control valve issue. very common.
HCJDM1's Avatar
the map sensor is on top of the throtle body ... o yeah and just make sure everything is pluged in correctly befor changing stuff ...
Old 02-15-2007, 02:26 PM
the idle air control valve is on the back of the intake manifold.
Old 02-15-2007, 02:30 PM
john457's Avatar
would a defective idle air control valve cause hesitant start. I have a new starter but when I turn the engine over it hesitates for a second before starting.
Old 02-15-2007, 02:32 PM
philosofy1's Avatar
Default Re: car keeps idiling fast and slow (ItR_98)
yes, a map sensor can cause this along with hesitation while driving.
lets keep in mind here, he hasn't said anything about CEL. when a map or IAVC goes out it'll throw a CEL. but if a FICis clooged or clogged PCV, no CEL and will cuse these symptoms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicGSRsi &raquo;</TD></TR><TR><TD CLASS="quote">I tellin u if its taking for ever to start its the battery and the idle is just from the AC being on </TD></TR></TABLE>
dude, what the hell are you talking about? you shouldn't start your car with the a/c on.
Old 02-15-2007, 02:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john457 &raquo;</TD></TR><TR><TD CLASS="quote">would a defective idle air control valve cause hesitant start. I have a new starter but when I turn the engine over it hesitates for a second before starting.</TD></TR></TABLE>
it is possible that you have a bad i.a.c.valve AND a weak battery. a bad starter will usually stay engaged longer than it should rather than hesitating. or there's always the possibility that its hesitating because its cold, or maybe you were low on gas.
Old 02-15-2007, 03:20 PM
john457's Avatar
what is a CEL & FIC?
Old 02-15-2007, 03:58 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john457 &raquo;</TD></TR><TR><TD CLASS="quote">what is a CEL & FIC?</TD></TR></TABLE>
a CEL is a Check Engine Light.
Old 02-15-2007, 04:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
a CEL is a Check Engine Light.</TD></TR></TABLE>
in the automotive business, the technical term is Malfunction Indicator Lamp, or M.I.L.
Old 02-15-2007, 04:41 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItR_98 &raquo;</TD></TR><TR><TD CLASS="quote">
in the automotive business, the technical term is Malfunction Indicator Lamp, or M.I.L.</TD></TR></TABLE>
LOL, thanks for the info.
Old 02-15-2007, 04:46 PM
LOL, thanks for the info. </TD></TR></TABLE>
no prob. its just useful to know because most service manuals and troubleshooting guides will refer to it as a MIL, not a CEL.
...:::MaRk:::...
13
07-23-2007 08:40 PM
Damon Reeves
07-09-2007 11:20 AM
GSR4U2NV
05-25-2006 09:02 PM
631 Teggy
11-07-2005 06:38 PM
RGoose18
05-20-2004 04:47 PM
Quick Reply: car keeps idiling fast and slow
