Engine Buildup Question.
Old Jul 30, 2002 | 09:44 AM
Four Door LS VTEC's Avatar
Default Engine Buildup Question.
This isn't R related....but there are some more technically inclined people in this forum so I thought I would give it a shot.
I have a Integra LS, the block has @130,000 miles on it. I have JE pistons (standard bore) and eagle rods that i am going to have installed.
My question is should my block be ok for the pistons, or should I either find a low mileage LS block or have the sleeves redone.
If you guys recommend having the sleeves redone, what would the parts cost and how difficult is it to do?
[Modified by Four Door LS VTEC, 2:03 PM 7/30/2002]
Old Jul 30, 2002 | 09:49 AM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: Engine Buildup Question. (Four Door LS VTEC)
all depends on how well the cylinder walls hone out- if they are very scored then you need to either bore it out and get oversized piston/rings, re sleeve it (call your local machine shop for costs- I have seen it vary ALOT, so call around), or simply get a block with less wear (not just less milage, less WEAR)
later
matt
Old Jul 30, 2002 | 10:20 AM
kenji's Avatar
25 Year Member
Default Re: Engine Buildup Question. (champITR)
With that many miles I would strongly suggest getting oversize pistons.
Installing a motor twice is never fun...
-kenji
Old Jul 30, 2002 | 10:21 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Engine Buildup Question. (kenji)
what he said
Old Jul 30, 2002 | 04:35 PM
thanks foR the Responses people...definitely taking them all in consideRation.
Old Jul 30, 2002 | 08:03 PM
01PYITR's Avatar
Why did he type every R in capitol?
Old Jul 30, 2002 | 08:12 PM
tonyxcom's Avatar
Default Re: Engine Buildup Question. (01PYITR)
must have turet's syndrome.
Old Jul 31, 2002 | 04:08 AM
Default Re: Engine Buildup Question. (tonyxcom)
[QUOTE]Why did he type every R in capitol?
[QUOTE]
it is now and r related thread.
buster97
Mar 2, 2016 12:21 PM
Einhander276
Sep 10, 2012 10:04 PM
fullracegsr
Feb 23, 2004 05:58 PM
Tropicana18T
Feb 23, 2004 03:40 PM
