Engin codes???
Old Dec 27, 2001 | 11:57 PM
ITR-1303's Avatar
Default Engin codes???
wondering how do get the engine codes to display??which wires must you have to short out to get the engine code readings??
thx
Old Dec 28, 2001 | 12:11 AM
Toda Party's Avatar
Default Re: Engin codes??? (ITR-1303)
1. Get a paper clip, and rebend it into a "U" shape
2. Open the passenger door, get on ur knees, look under the glove box, u should see the service connector taped under there...its Green
3. if u look inside, u see 2 separate small boxes, u want to stick the paper clip in so that its touching both metal pieces...its sorta tricky, u have to make sure the end of the paper clip are touching the metal, which is copper colored...
4. turn the key to the "on" position....the Check engine light (cel) will flash once really quickly, then turn off...then start to blink the code...
long blinks = 10
short blinks = 1
so long long long long, short short would equal 42
Old Dec 28, 2001 | 02:39 AM
BudMan's Avatar
Default Re: Engin codes??? (Toda Party)
Nice explanation Toda Party -
Here are some pics if that helps... http://www.bseries.net/html/garage/engcode.php
Old Dec 28, 2001 | 04:22 AM
Jason's Avatar
Default Re: Engin codes??? (BudMan)
here's what the codes mean http://www.c-speedracing.com/faq/05.html
Old Dec 28, 2001 | 11:51 AM
Toda Party's Avatar
hehe thanks, i had just done it about 2 hours before reading the post so it was fresh in my mind...i woudda taken pics too but it was like 3 am and it was 10 degrees outside
Old Dec 29, 2001 | 02:49 PM
ITR-1303's Avatar
thanks a lot i really appreciate it!!!
Old Dec 29, 2001 | 02:54 PM
tr4il's Avatar
Default Re: Engin codes??? (typer98)
so do you like do this if your check engine light is on? im not too smart on this topic...so you would just check the blinks and identify the problem???
Old Dec 29, 2001 | 05:22 PM
Toda Party's Avatar
Default Re: Engin codes??? (tr4il)
yes
tf87
Mar 7, 2019 04:00 PM
hndacord02
Nov 27, 2006 04:58 AM
NoLipRacen
Dec 9, 2003 09:27 AM
boostedsi1
May 23, 2003 10:13 AM
Hatchy-Ownzjo0
Aug 31, 2002 06:56 PM
