- Engine Code...help -
Old May 23, 2003 | 08:43 AM
boostedsi1's Avatar
Default - Engine Code...help -
I just bough a 2000 Civic Si on Wednesday night. I had to drive three hours to pick it up. I had not problems at all until I was driving it to work today and I get a check engine light. It doesn't flash, it is just a constant light. All I have been able to find when doing a search is flashing check engine lights, not a static light. Please help!
Old May 23, 2003 | 08:46 AM
b19coupe's Avatar
Default Re: - Engine Code...help - (boostedsi1)
It won't flash the code until you short the two pin SCS connector by the glovebox.
Old May 23, 2003 | 09:01 AM
DYNOFLO's Avatar
i was under the assumption that you needed to count the long flashes long and short and take it to reference http://londonautoclub.kicks-as...s.htm
Old May 23, 2003 | 09:02 AM
DYNOFLO's Avatar
yep sounds good
Mr Hammond's Avatar
a/k/a Jomo
A constant CEL means you are thorwing a code. To find out you can either A.) jump the service connectors and then the light will flash. First long equal increments of 10 then short ones for increments of one. So for example 9 long flashes and 9 short flashes equals code 99 (unknown). That's my favorite code or B.) you can use a PGM tester and hook it up to the on board diaognostics port under your ash tray. That's what I do.
Old May 23, 2003 | 10:13 AM
boostedsi1's Avatar
Default Re: - Engine Code...help - (Mr Milano)
I check it out as soon as I get out of work today. Thanks for all of your responses!
tf87
Mar 7, 2019 04:00 PM
stockton12
Jan 30, 2014 06:24 PM
mike_belben@yahoo.com
Nov 28, 2005 09:36 AM
jason1958
Aug 23, 2005 01:18 PM
Hatchy-Ownzjo0
Aug 31, 2002 06:56 PM
