did a compression test and....
Old Oct 3, 2002 | 12:52 PM
ITR #1202's Avatar
Default did a compression test and....
here is the #s I got
cyl #1 190
cyl #2 190
cyl #3 200
cyl #4 207
does that sound about right
Old Oct 3, 2002 | 12:57 PM
rs's Avatar
rs
Default Re: did a compression test and.... (ITR #1202)
Search! This is been covered numerous times.
Old Oct 3, 2002 | 12:58 PM
Dave-ROR's Avatar
cyl #1 190
cyl #2 190
cyl #3 200
cyl #4 207
how was the test done? 5 cranks and WOT?
if so, that's a little low with a bit of max varience..
Old Oct 3, 2002 | 12:59 PM
2.0L EK's Avatar
Yeah that sounds about right. GSR is suposed to be 180 across the board. My friends LS/Vtec was
290
295
293
294
The gauge only goes up to 300! I guess thats why it only ran on 110 octane LoL
Old Oct 3, 2002 | 01:01 PM
Dave-ROR's Avatar
Default Re: did a compression test and.... (2kTypeRHatch)
290
295
293
294
GS-R is supposed to be quite a bit higher than 180. Mine is was at 215 (avg) when I last checked it.
Old Oct 3, 2002 | 01:04 PM
Chubz's Avatar
Default Re: did a compression test and.... (Dave-ROR)
ive pinned the needle past 300 psi by a quarter of an inch every cylinders
Old Oct 3, 2002 | 01:08 PM
ITR #1202's Avatar
cyl #1 190
cyl #2 190
cyl #3 200
cyl #4 207
put the meter where the plugs are turned the car over for about 3 to 5 sec I
did this while at school.
Old Oct 3, 2002 | 01:09 PM
Dave-ROR's Avatar
cyl #1 190
cyl #2 190
cyl #3 200
cyl #4 207
try it again, this time disconnect the fuel pump fuse and hold the throttle wide open.
Old Oct 3, 2002 | 01:51 PM
Tommy_Gunns's Avatar
Mine was 225 max and lowest was 211 psi.
Old Oct 3, 2002 | 01:54 PM
CPR's Avatar
CPR
Default Re: did a compression test and.... (Tommy_Gunns)
Mine were
Cyl#1 - 220
Cyl#2 - 220
Cyl#3 - 225
Cyl#4 - 225
w/fuel fuse removed, cranked 5 times, at WOT.
Old Oct 3, 2002 | 03:27 PM
Racebrewer's Avatar
Default Re: did a compression test and.... (CPR)
Do the test with a warm motor.
John
Old Oct 4, 2002 | 06:34 PM
nsx-Animal's Avatar
Default Re: did a compression test and.... (Racebrewer)
John
Yes, you will get the right numbers..
watsvtecEK
Dec 18, 2005 07:28 AM
oMek
Oct 27, 2003 12:04 PM
JunIntegra
Jul 1, 2003 01:40 PM
speedymon
Jan 10, 2003 08:02 AM
