Coolant question
Old Sep 25, 2001 | 04:57 PM
itr501's Avatar
Default Coolant question
hey what kind of coolant is suitable for the R(preferably some stuff i can just pick up at kragen or target)? I know this might sound stupid but the manual kinda made it seem like the car was gonna break if i used non-honda products.
Old Sep 25, 2001 | 05:03 PM
Cosworth's Avatar
Default Re: Coolant question (itr501)
Kingmotorsports suggested 50% water-wetter + 50% h2o. I'm also interested in what other's use. I've gotta put the thermostat in sometime this weekend.
Old Sep 25, 2001 | 05:07 PM
R0476's Avatar
I always use Honda Coolant.
Old Sep 25, 2001 | 06:51 PM
nsxtcjr's Avatar
New User
Default Re: Coolant question (R0476)
Me too.
Honda has sent the information attached below to its dealers. While you might not expect the source to be exactly unbiased, it does provide technical information and justification for differences in their formula.
Genuine Honda Coolant is the Only Way to Go
Increasingly severe operating conditions and the advent of lower maintenance requirements have resulted in significant changes in the variety and the concentration of additives used in engine coolant. Also, the continual improvements in engine and vehicle design have challenged coolant suppliers to design products that perform well in a more demanding environment.
To meet these needs, Honda engineers have developed a superior, high-quality coolant that has several advantages over the competition.
Some antifreeze, although labeled as safe for aluminum parts, may not be compatible with Acura cooling system components. Extensive research and testing by both Honda R&D and CCI, the manufacturer of the Honda coolant, have proven that the abrasive silicates and/or borates found in most domestic coolants can cause these problems:
- - Silicates bond to the surface of the water pump seal and act as an abrasive, causing considerable seal erosion and coolant leakage. In actual tests, the silicated coolant caused early leakage. This leakage increased dramatically until a substantial portion of the coolant had been lost. In contrast, the Honda coolant had almost no leakage through the duration of the test.
Chart here, entitled "Coolant Leakage from Water Pump Seal", showing Leaked Coolant Volume in ml as follows for each test duration in Hours:
24 hrs: Honda Coolant 0, Typical Silicated Coolant 21
48 hrs: Honda Coolant 1, Typical Silicated Coolant 36
72 hrs: Honda Coolant 2, Typical Silicated Coolant 47
96 hrs: Honda Coolant 2, Typical Silicated Coolant 55
120 hrs: Honda Coolant 2.5, Typical Silicated Coolant 56
144 hrs: Honda Coolant 3.5, Typical Silicated Coolant 57
168 hrs: Honda Coolant 4, Typical Silicated Coolant 58.8
192 hrs: Honda Coolant 6, Typical Silicated Coolant 63
200 hrs: Honda Coolant 6, Typical Silicated Coolant 64
- - Silicates tend to gel and settle in the coolest parts of the cooling system, causing radiator plugging and overheating.
- - Borates cause pitting corrosion on the cylinder head.
- - Silicate inhibitors are difficult to stabilize and, therefore, limit coolant shelf life.
Most commercially available coolants were originally designed for cast iron engines. Silicate, an inexpensive additive, was added to coolants to prevent aluminum corrosion, but the long-term durability of the combination was not tested.
In contrast, Honda coolant was designed specifically for aluminum engines. It contains an organic corrosion inhibitor instead of silicate. This superior formula gives these advantages:
- - No silicate abrasion of water pump seals. For example, these graphs show the surface roughness of two aluminum water pump seal rings. Seal A, exposed to silicated coolant, shows considerable damage. Seal B, exposed to Honda coolant, displays only minute wear.
[graphs here, showing roughness across the surface, with A a very wiggly line, and B a very smooth line]
- - No plugging or overheating caused by silicate gelling.
- - Excellent corrosion protection for aluminum components.
- - Long-term corrosion protection for other cooling system materials (steel, cast iron, copper, solder, gaskets, seals, and O-rings).
You can find less expensive coolants on the market, but now you can see why genuine Honda coolant is the only coolant approved for Honda and Acura vehicles (it MUST be used for warranty repairs). Honda's non-silicate formula delivers added protection not offered by 95 percent of other brands. Since our customers expect lower maintenance, you're doing them an injustice if you use any other coolant.
Old Sep 25, 2001 | 06:56 PM
EPGONZALEZ's Avatar
Default Re: Coolant question (nsxtcjr)
you can add a little purple ice to your favorite coolant...or for race only..100% water and wetter..or purple ice..
Old Sep 25, 2001 | 07:02 PM
SamB's Avatar
New User
I use a mix of 25% coolant 25% water wetter 50% water. I only put the coolant in for when we go snowboarding, if it wasn't for that then I would use less coolant or no coolant at all (although I don't feel 100% comfortable with no coolant)
BTW, when I put the Water Wetter in it did make a difference, the car doesn't run any cooler on the gauge but it cools down alot faster.
Sam
P.S I use the Honda stuff as well.
[Modified by Sam & Bridget, 4:13 AM 9/26/2001]
Old Sep 25, 2001 | 07:17 PM
B2FiNiTY's Avatar
Default Re: Coolant question (Sam & Bridget)
Whats water wetter?
Old Sep 25, 2001 | 07:24 PM
Mike K's Avatar
Default Re: Coolant question (B2FiNiTY)
Water Wetter is an additive made by Redline. Good stuff.
I use 70% water and 30% coolant with Water Wetter. Combined with Spoon thermostat, radiator cap, and thermoswitch.. it REALLY helped cooling over just the factory Honda fill.
Old Sep 25, 2001 | 07:28 PM
R0476's Avatar
25% Water Wetter?!?! That must be expensive! I use like half a bottle of the stuff.
B2nifinty: Water Wetter is a coolant additive made by Redline, adding it in your cooling system lowers the temp of the coolant.
Old Sep 25, 2001 | 07:31 PM
SamB's Avatar
New User
Redline Water Wetter:
http://www.redlineoil.com/
Old Sep 25, 2001 | 07:39 PM
SamB's Avatar
New User
Yeah now that you point it out, I use 25% coolant 70something% water and about half a bottle of Water Wetter, Sorry about that stupid statement.
Sam the dumbass
Old Sep 25, 2001 | 08:23 PM
Toda Party's Avatar
My manual says: Use Honda Antifreeze/Coolante Type-2, with no dilution needed.
yoyosupmang
Honda Civic (2006 - 2015)
Aug 10, 2007 06:35 PM
UnrealSpeed
23
Aug 19, 2003 11:52 PM
Rvrrnr99
Jul 12, 2003 07:02 PM
T_Rex
Nov 9, 2002 06:21 PM
deviant1
Oct 24, 2002 07:25 PM
