Compresssion Difference
Old Jun 30, 2002 | 02:41 AM
PhoBichNga's Avatar
Default Compresssion Difference
What is the compression on the stock B16B pistons (Civic Type R) and B18C (JDM Integra Type R)?
Old Jun 30, 2002 | 03:42 AM
RICHJ's Avatar
Default Re: Compresssion Difference (PhoBichNga)
I believe both are 11:1 when in their correct engine
the CTR pistons in the B16B engine = 11:1
the JDM pistons in the B18C egnine = 11:1
If you put the CTR pistons in the B18C engine you get 12.5:1 ? (someone will have to confirm)
this is because you are compressing more cylinder volume of air (1.8L instead of 1.6L) in to the same space when it's compressed.
Old Jun 30, 2002 | 03:45 AM
RICHJ's Avatar
Default Re: Compresssion Difference - Direct replacement?
ALso I'd like to know are the CTR pistons direct replacement for ITR ones (with the obvious compression increase, ignoring extra fuel etc that would be needed).
DO these pistons run OK with say JUN III cams (I presume they do if JUN IIIs can be used in a CTR). Assuming they do I would assume they would work OK with a thicker gasket to reduce comp ratio (say to 12:1).
Anyone see any problems with my assumptions?
Old Jun 30, 2002 | 04:59 AM
Casey's Avatar
Default Re: Compresssion Difference - Direct replacement? (HardHead42)
the compression ratio with the ctrs stock will be right at 12:1. Jun 3s will work with the ctrs. Im not sure if they will work with ctrs and a mugen thin head gasket though(12.5:1 cr) for clearance reasons
Old Jun 30, 2002 | 06:07 AM
DutchITR1689's Avatar
CTR pistons in B16B will give you 10.8 compression.
Old Jun 30, 2002 | 08:17 AM
RICHJ's Avatar
Default Re: Compresssion Difference - Direct replacement? (CWTypeR463)
So CTR pistons in a B18C Type R with standard give 12.:1 compression and will clear JUN III cams.
Is anything else needed to add these pistons? Custom Rods?
Old Jun 30, 2002 | 08:39 AM
DonF's Avatar
You shouldn't need anything else to put in the pistons,but you will need springs and things for the cams. Try Kent as they have springs,retainers,pulleys, and cams. You will also have to lock the VTEC and check valve to piston clearance with those cams.
Old Jun 30, 2002 | 08:46 AM
YelLowITR's Avatar
ok.. i have CTR piston and took one layer gasket out, and my compression is run around 11.6-8 (high eleven)... but in the picture.. the piston on the top looks higher than the one on the bottom?
Old Jun 30, 2002 | 09:55 AM
Comp97GSR's Avatar
Default Re: Compresssion Difference (YelLowITR)
Right..... CTR pistons in a B18C5 is right around 11.3 with stock head gasket, with a geesr head it will be 11.8 with stock head gasket. Do a search, there is a link that will calculate different pistons/blocks to give you the compression ratio....and yes it should be fine with Jun III's
[Modified by Comp97GSR, 6:56 PM 6/30/2002]
Old Jun 30, 2002 | 09:59 AM
jonas's Avatar
piston on top = ctr
piston on the bottom = jdm itr
Old Jun 30, 2002 | 11:27 AM
sgT's Avatar
sgT
Default Re: Compresssion Difference (Comp97GSR)
No. CTR piston in a b18c with b16a head and stock gasket will be 12:1.
Old Jun 30, 2002 | 11:43 AM
Tomei's Avatar
New User
http://tiiite.b16a.com/lander/index2....com&term=b16a
Check this site out a bit later.
Old Jun 30, 2002 | 12:29 PM
Chubz's Avatar
CTR pistons in a b18c1 engine=12:3:1
CTR pistons in a b18c5 or b18c1/Pr3 head=12:1.
and CTR pistons work with JUN III in either a b18c5 or c1. Im currently running that setup in a b18c1/b16a head
[Modified by SuperTech, 9:30 PM 6/30/2002]
Old Jun 30, 2002 | 02:35 PM
PhoBichNga's Avatar
Default Re: Compresssion Difference (SuperTech)
How dangerous is it to run 12.1:1 compression for a daily driver and keep in mind I like to bang on my car .... are the CTR pistons a direct replacement for stock ITR ones without any extra mods to the bottom end or top end?
Old Jul 1, 2002 | 04:15 AM
RagingAngel's Avatar
Sounds like we got some chatting to do....
Bring MONEY.....
aris04
Jun 7, 2004 12:03 PM
ITR1071
Dec 25, 2002 04:26 PM
redteg1
Mar 3, 2002 06:52 PM
GQ 05YellowEVO8
Jan 12, 2002 09:38 PM
da6_b17a
Dec 7, 2001 10:29 AM
