compression numbers
Old May 13, 2003 | 05:41 PM
SmurfDA's Avatar
From: I live in a town with Boston traffic, mass, united states
Default hey guys
hey guys, my friend bought a 97 itr motor from jdm motorsports, has a 30 day warranty, we changed all fluids, pumps, belts, etc, today the car started smokeing, did a compression test, these are the numbers we got #1 - 196, #2 - 185, #3 - 176, #4 - 185......so my question is, what should the compression be? thanks in advance guys
Old May 13, 2003 | 05:44 PM
baonest1's Avatar
Default Re: hey guys (96LsIntegra)
as long as they are +/- 20 psi from each other
Old May 13, 2003 | 05:46 PM
SmurfDA's Avatar
Default Re: hey guys (baonest)
another ht member was telling me they should be above 200, is this true?
Old May 13, 2003 | 05:49 PM
tonyxcom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96LsIntegra &raquo;</TD></TR><TR><TD CLASS="quote">another ht member was telling me they should be above 200, is this true?</TD></TR></TABLE>
typically speaking yes, but I would be more concerned if they were uneven, which yours appear to be.
Did you guys check the timing belt and cam timing to make sure all is good there?
Did you do the test with the car fully warm and at WOT with distributor disconnected and all spark plugs out? How many times did you crank each cylinder?
Also, you may need to put 10-20 miles on the motor to clean out all the crap, who knows how long it has been sitting. Def change the oil again after a few hundred miles.
Old May 13, 2003 | 05:58 PM
SmurfDA's Avatar
Default Re: hey guys (tonyXcom)
yes, distributor was disconnected, all plugs out, 200 miles on motor, timing is fine, my friends dad is a honda mechanic and did the timing belt, and car was warm and tested at WOT i followed every instruction to do this, and those are the numbers.......
Old May 13, 2003 | 06:03 PM
Nameless RB26's Avatar
Did you do 6 cranks or 4?
Honda says to crank it 6 times.
Old May 13, 2003 | 06:05 PM
SmurfDA's Avatar
Default Re: hey guys (Nameless EJ6)
6, oh well, just gotta take it out and send it back, there goes another day
92lude91rex
Apr 25, 2006 05:41 AM
snowblind7x
Apr 13, 2005 08:12 PM
luckypon7
Jan 31, 2005 09:09 AM
TurboJesse
Sep 23, 2003 06:20 PM
