Changing oil pan question
Can the oil pan be changed from under the car without doing anything else but dropping the pan or am I in for surprises?
Just trying to switch out oil pans and need some info before hand.
thanks
thanks
Re: Changing oil pan question (kkim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim »</TD></TR><TR><TD CLASS="quote">
you sure there's no way around the header?</TD></TR></TABLE>
nope.......also you gotta remove the flywheel cover to get the 4 bolts it's covering.....
Re: Changing oil pan question (IN VTEC)
i've removed all that's listed... but i still can't take off the oil pan, seems to be stuck cuz of the sealant???
Re: Changing oil pan question (igyloo)
wow! sounds like you got your work cut out. kelly, are you switching out the oem pan for a "waffled" pan? hope everything works out.
kepani-who would like a myoogen waffled pan.
cyrix12
03-06-2006 10:30 PM
