CEL code#22. HELP
Old Oct 28, 2003 | 01:03 PM
NCcwITR's Avatar
Default CEL code#22. HELP
OK i pulled the code and I came up with #22.
*VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch*
What does that mean, and how do i fix it. Will my car be damaged or futher damaged if i continue to drive it?
Old Oct 28, 2003 | 01:31 PM
MAD ITR 55's Avatar
Make sure all the wires are still good and you have no broken connections.If the wiring is ok you might have to replace the pressure switch.It shouldn't damage your car by driving it,but the ecu will run in limp mode with the CEL on,and you will not go into VTEC.
Old Oct 28, 2003 | 01:33 PM
NCcwITR's Avatar
it doesnt run limp i dont believe.. cuz i still got VTEC
Old Oct 28, 2003 | 01:35 PM
MAD ITR 55's Avatar
So it still goes into VTEC?
Old Oct 28, 2003 | 01:36 PM
skunkintegra's Avatar
Default Re: (FBP ITR #0055)
quick question....
did you recently install the V-AFC??-- if so... might wanna check the wiring
had that happen to me-- same CEL
Old Oct 28, 2003 | 01:39 PM
MAD ITR 55's Avatar
Default Re: (skunkintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra &raquo;</TD></TR><TR><TD CLASS="quote">quick question....
had that happen to me-- same CEL </TD></TR></TABLE>
Yeah you could have a lose wire considering it still goes into VTEC.A VAFC does not engauge VTEC by oil pressure like the ecu does.So i'm pretty sure it's a broken connection somewhere.
Old Oct 28, 2003 | 02:08 PM
sa21199's Avatar
check your oil
Old Oct 28, 2003 | 02:18 PM
ZygSpeed's Avatar
Default Re: (sa21199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sa21199 &raquo;</TD></TR><TR><TD CLASS="quote">check your oil</TD></TR></TABLE>
I'd bet you can't find barely any on your dipstick!
Old Oct 28, 2003 | 05:13 PM
NCcwITR's Avatar
yeah, i just added about 2 1/2 quarts !.. CEL is off too btw
Old Oct 28, 2003 | 05:16 PM
Default Re: (NCcwITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCcwITR &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i just added about 2 1/2 quarts !.. CEL is off too btw</TD></TR></TABLE>
little too much vtec.... j/p
better keep ur eye on that
Old Oct 28, 2003 | 05:29 PM
NCcwITR's Avatar
so you think the extremely low oil was the cause for that CEL ?
Old Oct 28, 2003 | 06:48 PM
NCcwITR's Avatar
bump
Old Oct 28, 2003 | 07:35 PM
DCtwoR's Avatar
that what it sounds like...just be real careful and monitor your oil constantly...
btw, what part of NC are you from?
Old Oct 29, 2003 | 08:13 AM
MAD ITR 55's Avatar
Default Re: (RedlineR 106)
Never thought low oil would cause a CEL
Old Oct 29, 2003 | 02:13 PM
NCcwITR's Avatar
I am in Brunswick County, Farthest East, farthest South you can go in NC.
Old Oct 29, 2003 | 02:24 PM
Super7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCcwITR &raquo;</TD></TR><TR><TD CLASS="quote">so you think the extremely low oil was the cause for that CEL ?
You may need to reset the computer too. I continued to get the CEL off and on even after topping off.
Old Oct 30, 2003 | 04:52 PM
sa21199's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBP ITR #0055 &raquo;</TD></TR><TR><TD CLASS="quote"> Never thought low oil would cause a CEL</TD></TR></TABLE>
not enough oil not enought oil pressure no vtec vtec malfunction code 22
You might be burning oil too. Keep an eye on that
Old Oct 30, 2003 | 05:52 PM
NCcwITR's Avatar
say my car IS burning oil when i get into vtec. What short and long term effects could it have on my engine?
Old Nov 3, 2003 | 04:10 PM
sa21199's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCcwITR &raquo;</TD></TR><TR><TD CLASS="quote">say my car IS burning oil when i get into vtec. What short and long term effects could it have on my engine?</TD></TR></TABLE>
well when you run it hard like that w/o oil then it dies like mine
tamadrummer1120
Sep 17, 2009 09:20 PM
mortificationrock
26
Nov 18, 2008 09:08 AM
JinDIESEL
Sep 24, 2004 02:06 PM
tegon-gsr
Nov 5, 2003 08:16 PM
