ball joint problems
Old Jan 12, 2002 | 03:38 PM
fast-R's Avatar
New User
Default ball joint problems
Me a retard...I'm trying to do a clutch job, but I'm stuck. I cannot separate the lower arm from the ball joint. I've tried a mallet, joint seperator, and gear puller. No luck at all. Anybody have any ideas or suggestions?? Any help at all is appreciated, thanks.
Old Jan 12, 2002 | 04:23 PM
arren123's Avatar
Default Re: ball joint problems (fast-R)
I read that someone just removed the LCA instead of separating the ball joint.
Not sure if that works or not, but worth a try if you're stuck.
Old Jan 12, 2002 | 04:37 PM
sgT's Avatar
sgT
Use a sledge hammer. you probably arent hitting hard enough.
Old Jan 12, 2002 | 05:00 PM
fast-R's Avatar
New User
Default Re: ball joint problems (sgT)
hmm, both good ideas...thanks, I'll keep trying.
Old Jan 12, 2002 | 07:41 PM
NighthawkR184's Avatar
[Modified by flamencoR184, 4:47 AM 1/13/2002]
Old Jan 13, 2002 | 12:09 AM
Mista Bone's Avatar
D Tranny Guru
1" cold chisel or a wood splitter between the knuckle and LCA. Just stay away from the boot.
Old Jan 13, 2002 | 04:50 AM
gblaue's Avatar
Default Re: ball joint problems (Mista Bone)
BIG Sledge hammer.
Old Jan 13, 2002 | 07:30 AM
Batoutahell's Avatar
Default Re: ball joint problems (00ITR#756)
Budman separated his lca from the knuckle yesterday with a splitter tool (looks like a big-*** tuning fork), a 3.3lb sledge hammer, a good helping of advice from sgT...thanks!), and alot of whack!
Old Jan 13, 2002 | 07:36 AM
Robster's Avatar
the proper and easiest way is with a pitman arm puller, you can get them at any autoparts store for like $8-$12, besst money Ive ever spent, takes less than a minute to sseperate ANY ball joint. As always, leave the casstle nut on the last couple threads so they don't strip out. Also,, if the pitman arm puller you get has a pointed bolt on it, grind that bolt down, otherwise you'll cave in the hole for the cotter pin and that damages the thread alignment around the hole.
Robwster
Kevins89notch
21
Nov 4, 2013 06:17 AM
93sivtec
Jul 24, 2007 08:36 AM
LX4CYL
16
Feb 13, 2005 03:12 PM
rasinhell
Feb 3, 2005 01:47 PM
Vp Special K
17
Jan 6, 2004 02:08 PM
