Alignment / Steering Problem
Old Aug 9, 2007 | 08:45 PM
EG6R's Avatar
Default Alignment / Steering Problem
My steering wheel is slightly off centered. I need to put in an 11oclock position for the car to go straight. Otherwise the car and steering will pull to the right.
Ive already had both front ball joints, lca/uca bushings and tierods replaced.
I had it aligned:
Camber -1.5/-1.5
Caster (split) -.3
Toe 0/0
Ive also tried swapping my wheels fore and aft ; left and right. And they are already balanced.
It seems that the tug to the right is still there. What else could cause this?
Old Aug 9, 2007 | 08:53 PM
freakygeek's Avatar
Default Re: Alignment / Steering Problem (EG6R)
Road camber?
Old Aug 9, 2007 | 10:07 PM
EG6R's Avatar
Default Re: Alignment / Steering Problem (freakygeek)
Im pretty sure its not the road.
If i had a bent arm, they couldnt have gotten the car in correct alignment specs, right?
Old Aug 10, 2007 | 05:25 AM
jgirard's Avatar
Might be your passenger side axle, mine went out right before my warranty was about to expire and they replaced it, it would do the same thing and pull right. If it is that, make sure you get an alignment after it is fixed.
Old Aug 10, 2007 | 05:27 AM
Dave_B's Avatar
Has the wheel been off the car? Maybe it's off a spline? I know my JDM wheel is off one tooth of the spline and I'm going to pull it off and put it back. Not sure if yours has been off though.
Old Aug 10, 2007 | 06:25 AM
JjuuN R's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Has the wheel been off the car? Maybe it's off a spline? I know my JDM wheel is off one tooth of the spline and I'm going to pull it off and put it back. Not sure if yours has been off though.</TD></TR></TABLE>
His wheel being off a tooth wouldn't make the car pull to a certain side though?
Old Aug 10, 2007 | 06:27 AM
Dave_B's Avatar
Default Re: (JjuuN R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">
His wheel being off a tooth wouldn't make the car pull to a certain side though?</TD></TR></TABLE>
If your trying to hold the wheel straight it will...
Old Aug 10, 2007 | 06:30 AM
JjuuN R's Avatar
LOL
Old Aug 10, 2007 | 06:31 AM
Dave_B's Avatar
Trust me, it drives me nuts but I haven't had the time to fix it. Yes, only 10 mins of work but I might this weekend while prepping the PY for track at CMP.
Old Aug 10, 2007 | 06:40 AM
migs's Avatar
Camber -1.5L/-1.5R is perfect
Toe 0.0/0.0
Split Caster -0.3
A split caster issue WOULD NOT tug your steering wheel. An alignment pull with have ZERO affect on the steering wheel position.
If you have to fight the steering wheel that much, that would be the tire in which your vehicle is pulling to. Swap the tires from back to front, it should go away.
A balancing issue would only cause a vibration.
What kind of tires are you running?
Old Aug 10, 2007 | 10:02 AM
pcorad's Avatar
Default Re: (migs)
I heard a chasis alignment guy talk about "radial tire" pull years ago. That some radial tires can pull like mad.
My wife's jeep had this problem. Drove me nutz. Got new tires. Problem went away. My RSX has the problem too (Bridgestone Pole Position). I have swapped tires, played with inflations etc.
I think that one of the tires is substantially bigger than another and it's got some stagger like you might set up for an oval race (to faciliate turning left).
Old Aug 10, 2007 | 05:38 PM
EG6R's Avatar
The steering wheel was never removed. And the car would pull to the right as i let go of the wheel.
If i had a bent arm would it still be possible to get correct alignment specs?
Car is lowered 2" with adj camber kit. 16" wheels 215/45 RE01
Old Aug 10, 2007 | 05:55 PM
get RIGHT's Avatar
Default Re: (EG6R)
Are you driving an ITR or something else?
Old Aug 10, 2007 | 06:35 PM
migs's Avatar
Default Re: (get RIGHT)
Sounds like it is the tires.
Old Aug 12, 2007 | 04:15 AM
EG6R's Avatar
yes its a dc2
Could it be a bent arm? Or not possible since i got it into correct alignment specs.
Old Aug 12, 2007 | 06:29 AM
migs's Avatar
Default Re: (EG6R)
How bad is the pull? Try a different set of wheels. The caster specs can be closer to 0.00 if possible.
Old Aug 12, 2007 | 07:20 PM
EG6R's Avatar
Default Re: (migs)
It pulls as soon as i let go of the steering.
I tried swapping my wheels but in different directions but they all pull to the right
Old Aug 13, 2007 | 12:02 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (EG6R)
the alignment of your steering wheel has nothing to do with why your car pulls... i would take it back into the alignment shop and have them recheck it, and while there at it straighten out the wheel like they should have when doing a proper alignment.... it sounds like the toe may be off a little bit or they didnt compensate for the crown in the road...
take it to a reputable alignment shop, explain your issues and they will work with you to get it straightened out
Old Aug 13, 2007 | 04:32 AM
migs's Avatar
Default Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">the alignment of your steering wheel has nothing to do with why your car pulls... i would take it back into the alignment shop and have them recheck it, and while there at it straighten out the wheel like they should have when doing a proper alignment.... it sounds like the toe may be off a little bit or they didnt compensate for the crown in the road...
take it to a reputable alignment shop, explain your issues and they will work with you to get it straightened out </TD></TR></TABLE>
His alignment specs were mentioned in the first post. The only area in grey is the caster, in which our cars is not adjustable.
Old Aug 13, 2007 | 05:49 AM
EG6R's Avatar
Ive gone to the alignment shop 4x in the past month.
Im kind of narrowing it down to a bent arm or knuckle since i pretty much replaced most of the moving parts. Is it possible?
Old Aug 13, 2007 | 06:09 AM
r573's Avatar
Default Re: (EG6R)
were are you going for this alignment? there suppose to lock that wheel strait while there doing it. If anything I could understand the car pulling but at this point not the car going strait at 11.
tonykdee
Honda Civic (2001 - 2005)
May 27, 2009 07:49 PM
EG6R
Suspension & Brakes
Aug 6, 2007 01:46 PM
Playa_FL
Mar 10, 2006 07:54 AM
WangChung
36
Dec 10, 2003 07:34 AM
ultimatehonda
Jul 8, 2003 03:28 AM
