Alignment expert ......Toe spec
Old Apr 9, 2002 | 06:41 PM
bus stop's Avatar
Default Alignment expert ......Toe spec
I remembered some ppl said " 1/8 degree of total toe out in front and zero degree of toe in rear " can help the car rotate better.....
Also, someone said using " Max toe out within spec in front and zero toe in rear " can help too......
My first question is: Which setting has MORE toe out? 1/8 total or Max within spec ??
Second, I've the Honda service manual as well as a print out from someone's alignment in front of me but I just can't figure out.
Standard .................( New )
In the manual Total toe (front) : 0 +/- 2 ..................... (0+/- 0.08)
Specified ..................... Range
From the print out Total toe (front): -0.16* ....................... 0.16*
* = degree
Are those number equal to each others ??
I want to make sure I got the right alignment setting.......Thanks for your help
Oscar
[Modified by WhosITR, 8:18 PM 4/9/2002]
[Modified by WhosITR, 8:19 PM 4/9/2002]
Old Apr 9, 2002 | 06:43 PM
bus stop's Avatar
Default Re: Alignment expert ......Toe spec (WhosITR)
I wish the search fuction work so I can find more info on this topic.....
Btw.......Anyone knows the actual ITR alignment spec ??
[Modified by WhosITR, 8:55 PM 4/9/2002]
1990IntegraLS
Jan 14, 2016 10:25 AM
texcon
Suspension & Brakes
Aug 5, 2013 06:27 PM
clement_h
Mar 21, 2003 12:00 PM
1.7na
Mar 20, 2003 03:22 PM
bus stop
11
Apr 14, 2002 07:06 AM
