ABS codes!! I need 15 and 53!
Old 07-20-2004, 04:59 AM
ATgrills.com's Avatar
Default ABS codes!! I need 15 and 53!
Well I put my car in reverse and it made a screching noice,, now my abs light is on..
when I check the codes I get code 15 and 53 on the cluster
can someone please let me know what that code it!
thanks
Tyler
Old 07-20-2004, 05:02 AM
sylvain's Avatar
Default Re: ABS codes!! I need 15 and 53! (ATgrills.com)
ABS code or Engine code, witch light is on ?
Old 07-20-2004, 05:35 AM
Default Re: ABS codes!! I need 15 and 53! (sylvain)
lol well i have bother on,,,,
abs blinks 15 and 53
and engine blinks 4!
thanks
Old 07-20-2004, 05:52 AM
sylvain's Avatar
ABS
15 is a wheel sensor open/short
53 is motor stuck on
Probably a defgault in the wiring loom or short circuit somewhere, chez the cables under dash or next the ABS Unit.
Engine
14 is CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor
Old 07-20-2004, 05:56 AM
is 15 rear right.... someone told me that
and for the engine code, I was told either my timming belt is off my 1 tooth or the distributor is screwed!
what you think!
Old 07-20-2004, 06:04 AM
sylvain's Avatar
If the timing belt is not right or distributor sensor pb, you might have the 54 code :
CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
It's not the same.
Old 07-20-2004, 06:07 AM
so then what would 4 be? as in what would be the first thing to do to try and fix it?
Old 07-20-2004, 06:10 AM
sylvain's Avatar
U don't have the Acura repair manual in PDF ?
Old 07-20-2004, 06:26 AM
nope! is there any way you can send it to me?
tleschuk@hotmail.com!
thanks!
Old 07-20-2004, 12:55 PM
sylvain's Avatar
I have to make some free space on my web server and i will post the download link tomorrow.
Old 07-20-2004, 10:52 PM
Rom1's Avatar
Salut Sylvain,
Same things for me:
https://honda-tech.com/zerothread?id=923454
alexthegreat5
Honda CR-V & Element
07-30-2018 05:19 AM
tobytigger
06-23-2015 04:31 PM
stiness101
07-06-2010 03:50 AM
fanatic
10-20-2004 01:30 PM
Quick Reply: ABS codes!! I need 15 and 53!
