How do you change your transmission fluid?
Old Jul 19, 2002 | 08:38 AM
wessieball's Avatar
Default How do you change your transmission fluid?
I was wondering what is needed to change your transmission fluid? Are there any special precautions I need to be aware of? Any input would be appreciated.
Old Jul 19, 2002 | 09:00 AM
Crazydave's Avatar
Default Re: How do you change your transmission fluid? (wessieball)
you will spill some on the ground.
you need to undo the drain bolt..
let it drain.
put drain bolt back in..
undo fill bolt..
put new fluid in until it starts to come out..
Old Jul 19, 2002 | 09:13 AM
avs's Avatar
avs
The way to change tranny fluid is first drain out the old fluid, then fill it up with some new fluid and shift the car to different gear then drain out the fluid again. Do this until the fluid is clear.
Old Jul 19, 2002 | 10:42 AM
CHEETAH's Avatar
Default Re: How do you change your transmission fluid? (avs)
you're correct !!!
not too many people do this though, so the residue is still in there after the 1st change.
also, my process in changing oil, drain at the drain plug, pull of fill plug and leave it off(dont fill from fill plug, too much effore), pull out VSS sensor from top (one 10mm bolt holds it), full with long stem and fill until it starts to drip out of fill plug, replace fill plug, add lil extra and you're done.
Greg
Old Jul 19, 2002 | 11:00 AM
sleeperaccordv6's Avatar
From: west Ft.Worth, Texas, the big one in the center
Default Re: How do you change your transmission fluid? (CHEETAH)
what about the auto?
Old Jul 19, 2002 | 11:38 AM
Kamin's Avatar
wait wait.
so the correct order to flush the transmission is
drain
fill
shift gear
drain
refill?
Old Jul 19, 2002 | 11:42 AM
IlikeTODA's Avatar
Greg
That sounds alot easier than taping a funnel to the end of a hose and pouring from top in the fill hole, like I've always done. Thanks for the good info.
Thanks, J
Old Jul 19, 2002 | 11:48 AM
Speed_Ricer99's Avatar
hmm... Never done it that way. Makes sense, but it would take forever
that would also be expensive to if you fill it completely up and drain it.
2.2qt's x 5 gears 11 qt's
Old Jul 19, 2002 | 12:03 PM
YeuEmMaiMai's Avatar
ok easier way to do if you have a auto
1. buy a bottle of Lube Guard
2. take car to Jiffy Lube or any other place that uses a Wynns Tranny flush machine
3. For $80 let them hook up the machine and your car will exchange all the fluid in the tranny with new Dextron II
4. Add one bottle Lube Guard that you bought
Old Jul 19, 2002 | 12:32 PM
avs's Avatar
avs
Default Re: How do you change your transmission fluid? (KAMiN)
Yes this way you can get all the residue out. Just watch and see...the first 2 flush you gonna see black fluid(depend on when the last time you change the fluid). Yea changing it in Jiffy lube is nice and easy, but for $80? I wouldn't spend $80 to let them do it if i know how to do it. It's not expensive @ all to do all this procedure. For the first few flush. Just buy some cheap tranny fluid from Wal-Mart or something. I think around $3 for a gallon, then for the last final fill up, buy some higher quality fluid.
Old Jul 19, 2002 | 12:45 PM
Lei Siew Long's Avatar
you're correct !!!
Greg
good info. but, i don't understand why you would remove the VSS. do you fill it from there?
Old Jul 19, 2002 | 12:46 PM
i am lazy to mees with autp tranny fluid because it brings out all of the flies and crap that are attracted to the sweet smell
Old Jul 19, 2002 | 12:56 PM
avs's Avatar
avs
Hey Cheetah or anyone else, educate me what a VSS sensor is. thanks
Old Jul 19, 2002 | 01:28 PM
Chiovnidca's Avatar
Vehicle Speed Sensor.
Old Jul 19, 2002 | 05:58 PM
Default Re: How do you change your transmission fluid? (Teken)
a lot of honda dealers only use the drain and fill method....if you look at it this way
$60 for a drain and fill
or
$80 for a complete exhange plus $11 for lubeguard
I pay the $90 anyday
BTW that lube guard is worth every penny as it does work as advertised
Old Jul 19, 2002 | 06:05 PM
avs's Avatar
avs
Yea you get the most out of it. Drain it out until it's clear. That's all. If you got the money to spend. Go ahead. Not me.
Old Jul 19, 2002 | 10:16 PM
piscorpio's Avatar
Default Re: How do you change your transmission fluid? (YeuEmMaiMai)
All I did was drain and refill basically. I was following my Helms, I thought I was doing it right?
Old Jul 20, 2002 | 05:29 PM
Halo's Avatar
Default Re: How do you change your transmission fluid? (piscorpio)
what's the benefit of adding lubeguard?
JennyPooh
40
Nov 4, 2010 11:17 PM
Too_Funny
Nov 8, 2002 03:34 PM
Y2KGreenGSR
Sep 28, 2001 12:11 PM
sackdz
Jun 26, 2001 04:17 AM
