Window noise?
i would think you gotta take off the door panel and tighten some screws that hold the window in place when you move it up or down....cause i only get it when my window is partially rolled down!
it's not the motor it the rubber strip on the side of the rail that guides the widow inside the door, it probably fell off
this is the right place to start as this person mentioned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2long »</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...D=552</TD></TR></TABLE>
but in this article they only show that the problem is on the side closer to the lock, i had the same problem but on the other side closer to the door hinges. check both sides when u take off door panels and such.
good luck
good luck
My window rattles when I close the door if the window is cracked open slightly. All the rubber strips are in place. I think it's the guide near the top of the window rattling in the guide track, but I do not know of any way to fix it.
soon2bdropped
Mar 23, 2009 07:53 PM
