no O2 sensor searched!!
Old Jun 5, 2007 | 12:03 AM
urquidezj's Avatar
Default no O2 sensor searched!!
so it doesn't have one. 94 teg. b16 black gsr head, type r intake mani. the sensor is on its way so its not on yet. my car is running like crap. idles randomly up and down, is runing really rich I can smell it. cheked codes, I get a 41 heater for the O2 but there is no sensor. gas mileage is awful. so,, will the O2 sensor fix all this??? please imput will be apreciated.
julio
Old Jun 5, 2007 | 05:54 AM
Liu Kang's Avatar
Default Re: no O2 sensor searched!! (urquidezj)
https://honda-tech.com/zerothread?id=1958333
Old Jun 5, 2007 | 09:08 PM
urquidezj's Avatar
Default Re: no O2 sensor searched!! (Liu Kang)
ok.. any people not running one for whateve reason. any negatives
Old Jun 5, 2007 | 09:52 PM
CypressGreenDC2's Avatar
The only people I hear of not running a O2 sensor is when the car is tuned and running closed loop. Then they just use a wideband O2 sensor.
Old Jun 5, 2007 | 11:23 PM
1.8L_allmotormilitia's Avatar
o2 is whats making your car run real rich. only way i know people not running o2 sensor is it they have chipped ecu or tuned car that eliminates the o2/knock sensor out of the whole ecu with the program...
Old Jun 6, 2007 | 09:46 AM
urquidezj's Avatar
Default Re: (1.8L_allmotormilitia)
wanted to make sure becuase i didnt want the whole running rich thing to mess up the O2 sensor..
Old Jun 13, 2007 | 08:49 PM
urquidezj's Avatar
Default Re: (urquidezj)
ok so its on, no cel, but, i can still smell a bit of richness what can it be???? timing? it has an adjustable fuel regulator, could it be throwing to much gas? thanks
Old Jun 13, 2007 | 08:57 PM
no2unenolife's Avatar
its your o2 sensor, you need one because then you have no sensor that can determine the amount of fuel it needs, right now its in a mode where its being safe because you have no sensor, so it just dumps fuel. get an o2 sensor.
Old Jun 13, 2007 | 09:11 PM
numbnuts22715's Avatar
so you installed the o2 sensor?
you may need to disconnect the battery or unplug the ecu fuse. It needs to reset.
Then it may take 60 miles or so for it to completely reset.
I hope that solves your problem.
Old Jun 19, 2007 | 10:16 PM
urquidezj's Avatar
Default Re: (numbnuts22715)
reset and everything but still smells a bit rich. the irregular idle went away though so...
odishaw
Feb 16, 2008 08:34 AM
ken2830
Feb 1, 2008 12:09 AM
k9n
Jun 9, 2006 02:58 PM
arjusmc
Oct 23, 2003 04:26 PM
tonylude94
Aug 21, 2003 01:26 PM
