When checking for codes ABS light is falshing
Old Jun 14, 2004 | 06:54 PM
tom153's Avatar
Default When checking for codes ABS light is falshing
Alright,
My Maint Req. light started flashing when i would start the car a couple of days ago, so when I checked for codes, the ABS light started flashing (threw a 21). I looked at the codes and 21 is supposed to be a Vtec solenoid failure or something; however, I have an LS.
What could be the problem guys?
Thanks,
BTW, it's a '95 LS
Old Jun 14, 2004 | 07:21 PM
timmy8151's Avatar
Default Re: When checking for codes ABS light is falshing (tom153)
For 94-97 tegs a code 21 is a parking brake problem.
Old Jun 15, 2004 | 03:38 AM
JimBlake's Avatar
Default Re: When checking for codes ABS light is falshing (timmy8151)
The only way for ABS to 'know' anything about the parking brake is by the same circuit that lights up the 'brake' lamp in the cluster. So that's where you can start looking, for example the little switch button at the handbrake lever.
Old Jun 15, 2004 | 05:22 PM
tom153's Avatar
Thanks,
Ill do that prolly this friday
Old Jun 17, 2004 | 01:08 PM
emsAARON's Avatar
When diagnosising the codes I am getting three short flashes ten seconds apart on my ABS light...then it stays out.
Anyone know what this means?
Old Jun 17, 2004 | 01:28 PM
JimBlake's Avatar
Default Re: When checking for codes ABS light is falshing (emsAARON)
It would be good to know what year, because they changed the ABS system somewhere around '98. I think the codes changed at that time, too.
Old Jun 17, 2004 | 03:33 PM
emsAARON's Avatar
Default Re: When checking for codes ABS light is falshing (JimBlake)
Sorry...I thought my sig was included...
It is a 94 Accord EX Auto
I am not sure if it was three seperate long flashes or what...it was very different from the CEL and the D4 light flashes.
Again, it stopped completely after the third flash.
Aaron
Old Jun 17, 2004 | 06:25 PM
RallyRedGT-V6's Avatar
wait...maintance required? just press the little button under your dash
Old Jun 21, 2004 | 04:35 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emsAARON &raquo;</TD></TR><TR><TD CLASS="quote">Sorry...I thought my sig was included...
Aaron</TD></TR></TABLE>You might want to check the tech or Accord bb. I don't know if it's exactly the same ABS system as the Integra...
grassmarine762
May 29, 2013 07:31 AM
lovelove
Jan 28, 2010 04:46 PM
RotaryPWR
Aug 12, 2009 11:36 AM
newhondaowner29
Jan 11, 2006 08:11 PM
f22suzuka
Apr 21, 2004 10:15 AM
