When checking for codes ABS light is falshing
Alright,
My Maint Req. light started flashing when i would start the car a couple of days ago, so when I checked for codes, the ABS light started flashing (threw a 21). I looked at the codes and 21 is supposed to be a Vtec solenoid failure or something; however, I have an LS. What could be the problem guys? Thanks, BTW, it's a '95 LS |
Re: When checking for codes ABS light is falshing (tom153)
For 94-97 tegs a code 21 is a parking brake problem.
Re: When checking for codes ABS light is falshing (timmy8151)
The only way for ABS to 'know' anything about the parking brake is by the same circuit that lights up the 'brake' lamp in the cluster. So that's where you can start looking, for example the little switch button at the handbrake lever.
Thanks,
Ill do that prolly this friday |
When diagnosising the codes I am getting three short flashes ten seconds apart on my ABS light...then it stays out.
Anyone know what this means? |
Re: When checking for codes ABS light is falshing (emsAARON)
It would be good to know what year, because they changed the ABS system somewhere around '98. I think the codes changed at that time, too.
Re: When checking for codes ABS light is falshing (JimBlake)
Sorry...I thought my sig was included...
It is a 94 Accord EX Auto I am not sure if it was three seperate long flashes or what...it was very different from the CEL and the D4 light flashes. Again, it stopped completely after the third flash. Aaron |
wait...maintance required? just press the little button under your dash
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emsAARON »</TD></TR><TR><TD CLASS="quote">Sorry...I thought my sig was included...
It is a 94 Accord EX Auto I am not sure if it was three seperate long flashes or what...it was very different from the CEL and the D4 light flashes. Again, it stopped completely after the third flash. Aaron</TD></TR></TABLE>You might want to check the tech or Accord bb. I don't know if it's exactly the same ABS system as the Integra... |
