Wheel Vibrating
might need your balance and alignment done i just had that happen to me on my hatch...just need to get a wheel balance and got my car aligned and now im as good as new.
good luck trouble shooting.
It is most likely one of the other things listed above. I'd check those first. balance rim/tire, alignment, lug nuts, air pressure, then move on from there if you find the same symptoms occuring.
I had a similar problem a couple months ago and it ended up being one of the axles. I put it on a friends lift and drive the car while in the air - you could see the axles out of round. See if you can have someone else do the same for you - if you have any friends, etc that have access to lifts. Start with the least expensive option - visable problems.
Then I'd go the following route:
1. Lug Nuts / Tire is on properly
2. Wheel Weights / Balancing
3. Alignment
4. RE-check/install axle.
3. Alignment
verycleanhatch
Oct 26, 2006 09:00 PM
