what should I replace when pulling my head?
Old May 25, 2006 | 02:36 AM
GsDAteg's Avatar
Default what should I replace when pulling my head?
I am about to buy a head off a 99' Integra that only has like 35K on it. My stock motor has about 200K on it and doesnt burn or leak any oil. When I pull my stock head off to put on my new B18B head, what should I do to freshen up my block?? Even though the block is in good running condition now keep in mind it has around 200K and I want to start boosting soon, around 12-15psi. What would you guys reccomend I do to it?? Full rebuild?? Or can I just get away with some key parts.
Basically, what would you want to replace if you were in my situation and and getting ready for boost.
Old May 25, 2006 | 05:30 AM
1g's Avatar
1g
12 psi? min? full rebuild
Old May 25, 2006 | 09:23 AM
trick_db's Avatar
Default Re: what should I replace when pulling my head? (GsDAteg)
keep it stock, and daily boost it.. 8 psi and 9 is perfect for daily and cost less?
Old May 25, 2006 | 09:50 AM
DA is best's Avatar
just keep in mind when/if you boost it that your block still has arround 200k so try not to beat on it 24-7.. but just replace all your gaskets/seals and maybe resurface your head if you can
Old May 25, 2006 | 09:53 AM
DA is best's Avatar
8-9psi not 12-15psi then your risking breakin $hit more than you'll already be heading towards
Old May 25, 2006 | 12:39 PM
Deluzional's Avatar
Default Re: (derek21)
id definitely think about rebuilding it, and upgrading with some aftermarket pistons/rods. IMO even with a damn good tune, 12psi-15psi at 200k is pushing it
ekhondahudson
Mar 17, 2014 03:46 PM
92LSVTEC
Apr 7, 2007 11:06 AM
redsikiller
Nov 11, 2005 09:46 PM
tonesdef
Jun 11, 2003 05:47 PM
servion
Oct 20, 2002 10:37 PM
