what is the prob?
Old Aug 23, 2007 | 03:08 PM
shawndb1's Avatar
Default what is the prob?
I have a 92 integra rs and everytime im under 40 km/h (canadian) theres a noise coming from the top right (near the wheel). As soon as I press the break, the noise goes away
ps: at certain speeds my spedometer needle vibrates, what can i do?
Old Aug 23, 2007 | 03:09 PM
Da9Gro's Avatar
Default Re: what is the prob? (shawnash)
do simple checks around the wheel, be sure to check the break pads
Old Aug 23, 2007 | 03:10 PM
shawndb1's Avatar
Default Re: what is the prob? (Da9Gro)
i passed for inspection since I was buying the car, and the breaks were A1, since the seller recently changed them.
Old Aug 23, 2007 | 03:14 PM
Da9Gro's Avatar
what noise does it make?
Old Aug 23, 2007 | 03:15 PM
shawndb1's Avatar
da9gro, i cant IM, my msn : ballinboi_@hotmail.com
Old Aug 23, 2007 | 03:17 PM
Da9Gro's Avatar
only got Aim
Old Aug 23, 2007 | 03:19 PM
shawndb1's Avatar
the noise is like a "ssssssssssssssss" a clear, crisp one lol
Old Aug 23, 2007 | 03:20 PM
Da9Gro's Avatar
im sorry i just dont kno how to sound that out, but if i say ssssssssssssssss probably sounds like an air leak lol
Old Aug 23, 2007 | 03:22 PM
shawndb1's Avatar
its not air lol i checked that out only does it when im at 40 or less, and when i hit the break its gone.
Old Aug 23, 2007 | 03:26 PM
Da9Gro's Avatar
are you sure its comin from the wheel? do you have a sound system in you car, if so there could be a bad ground because the ground usually gets louder as you accelerate
Old Aug 23, 2007 | 03:31 PM
hatchling37's Avatar
Look at your brakes. I bet you have a little pebble stuck in between your caliper and pad. Happened to me about two months ago...
Old Aug 23, 2007 | 04:23 PM
Rainmaker's Avatar
I suppose it _could_ be a bad wheel bearing...
Old Aug 23, 2007 | 04:33 PM
SoTexDC2's Avatar
I had that problem after a brake job a while back. Take the wheel off and look for anything out of the ordinary.
Mine turned out to be a shim that worked itself loose and was rubbing on the rotor. This may, or may not be your problem. It really depends on the pads you use, specifically whether or not they have shims.
k20eklipse
Aug 3, 2010 08:40 PM
del sol1658
Jun 6, 2006 12:54 PM
Orangedragone
Apr 27, 2006 08:52 PM
honda4674
Nov 1, 2005 07:40 AM
3rd accord
Sep 20, 2004 08:28 PM
