Weird Noise from Wheel (VIDEO)
I have been hearing a very weird noise coming from my front right tire...I have included a video of the noise. You will hear the noise when I let off the gas.
Click here to watch Weird-noise-62
Thanks, I really dont want my wheel coming off when Im going to work.
uhm. sounds like its your plastic **** form the bottom rubbing maybe? or even something in the transmission?
its hard to tell. put your front end up on blocks and run it see if u can locate it that way
EDIT: i am not held responsible if ur car falls off and u hurt something/someone
Re: (del sol1658)
umm not sure what we were supposed to be listening for there, but as long as your lugnuts are tight/torqued down you shouldn't have a problem with your wheel falling off on your way to work. but it sounds (not from the video, just from experience) like it could be the fender lining.
Re: (EGRhatch)
You cant hear it untill the last half of the video, sorry for not editing it.
You can hear my the exhaust slightly, and the rest is the weird noise. It sounds like somthing is rubbing, but nothing is hanging down. The noise gets loud in the cabin when the windows are rolled up.
Re: (del sol1658)
you drive in sandals?? FREAK
Well.. like i told you before, it could be motor mounts or suspension bushings, the vibration of accelerating might make that noise
When i had your car on the lift i noticed a couple of motor mounts were shot along with most of ur bushings, you should replace thoes and see if it fixes it.
Re: (VtecAdvantage)
Thank you justen...
Well the noise goes completly away when you push in the clutch. The car needs alot of new things, so might aswell start replacing ****.
k20eklipse
08-03-2010 08:40 PM
FSUseminoleEM1
02-01-2010 05:42 PM
legendisdope
01-09-2007 02:40 PM
