what the hell is this?
Old Apr 2, 2010 | 09:22 AM
lickety_britches's Avatar
Default what the hell is this?
so i just deleted my abs to put my jdm hids in, and i go to put the headlights in, and i run into what looks like some kind of pump on the driverside. its placed behind the washer fluid resevoir (which i removed because i have no wipers). im not running into the pump itself, but there seems to be some kind of breather cap or something like that stick out the top of a hard metal line that comes out of it. and i cant seem to find online anywhere what this could be. so someone help me. this HID issue is becoming a pain.
Old Apr 2, 2010 | 09:35 AM
Default Re: what the hell is this?
thats the only pic i could find that you could see it. the little cap at the bottom of the green circle is whats in my way.
Old Apr 2, 2010 | 09:37 AM
foxfai's Avatar
That's the AC line/component.
Does the blue cap has a "H" on it? That's the high pressure side.
Old Apr 2, 2010 | 09:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yep don't try to open or remove that unless you want to remove A/C or otherwise have to get your system recharged at a shop (have to pull down vacuum first and replace the oil).
Old Apr 2, 2010 | 09:53 AM
yes it does. is there anything i can do about this? i mean, ive already started wiring, and deleted my ABS, and itd suck bad if this is whats gonna stop me from puttin them in
Old Apr 2, 2010 | 10:11 AM
nvm guys, i read somewhere where you can just bend it, i was afraid bending it wasnt a good idea, but i got em in : ) thanks for all your help
mikemikelude
Nov 16, 2017 03:53 PM
track_assassin
Apr 29, 2014 06:09 PM
alvinoolivas
11
Jul 18, 2011 10:01 PM
slockm
Jun 21, 2008 04:24 PM
all stock
Mar 8, 2003 01:03 PM
