AC Vacuum pumping questions
Old Jun 20, 2008 | 07:41 PM
slockm's Avatar
Default AC Vacuum pumping questions
Can you give me an idea of how long it should take to pull a vacuum on my AC system with an electric vacuum pump? I let mine run for ~20 minutes tonight and it only pulled ~5inches. I shut it down, locked it up, and I'll see if it remains the same by tomorrow morning. Should it take that long to pull a vacuum?
On a similar note, what is the best way to detect a leak in the system? I have a sniffer - should I go ahead and put in one can of refrigerant in the system and sniff out a leak?
Thanks,
M
Old Jun 21, 2008 | 04:24 PM
Bounce's Avatar
Default Re: AC Vacuum pumping questions (slockm)
What kind of pump is it? I have a 3cfm 2 stage and it will pull down to 30 inches pretty quick. If after 20 minutes you don't get a good vacuum you either have a leak or a bad pump. Put a can of 134 (I assume that's what you're using) in there and give it a sniff. If you can't find anything try injecting some dye. Also, if you have had the system opened you need to replace the filter drier and put the correct amount of the right type oil for your car back in before you re-assemble, vacuum, and charge.
flanker
39
Mar 25, 2015 08:56 PM
NIKADEM0
Honda CR-V & Element
Jul 22, 2013 10:59 AM
92'si
Jun 26, 2007 07:03 AM
LoneStarCRX
13
Apr 18, 2006 08:10 AM
Emery
Jul 15, 2004 01:13 AM
