d16 civic misfire problem, help!
Old 01-31-2011, 09:31 PM
CPreston's Avatar
Default d16 civic misfire problem, help!
i have a 98 civic with a d16y8 and 215000 miles. the car misfires or like cuts in and out really fast when im either a low rpms in a high gear, or at any gear after 5500 rpms, and it always happens.
i have next to no money at all and i cant just start replacing things to see if its the problem..
i was thinking it might be a fuel filter causing it not to get enough fuel, or maybe the plugs but idk, hoping someone else has had the same problem.
Old 01-31-2011, 09:47 PM
delsolo95's Avatar
Default Re: d16 civic misfire problem, help!
when was the last time you replaced the plugs, wires, and cap n rotor? also could be many things...here check this out.
http://www.aa1car.com/library/misfire.htm
Old 01-31-2011, 10:51 PM
jonesEK's Avatar
When i would take off the car would randomly misfire (not all the time) It was the spark plug wires... I also replaced the plugs too.. delsolo
Old 02-01-2011, 09:03 AM
CPreston's Avatar
im probably gonna get new plugs and wires and maybe the fuel filter, it could use them anyway.. the car sat for awhile before this started happening too, i forgot to mention.
Old 02-01-2011, 09:22 AM
Former User's Avatar
Any CEL codes?
Old 02-01-2011, 11:16 AM
CPreston's Avatar
the check engine light is on, i havent checked the codes yet though
Old 02-01-2011, 11:20 AM
Post the codes when you have them. Then reset the ECU to see whether any of the codes repeat after some driving.
kelviiv
09-16-2008 03:58 PM
superdat1
05-01-2008 10:20 PM
civicferio8381
04-06-2005 06:20 AM
Project_Civic
04-03-2005 05:07 PM
cyr0ch
07-29-2004 04:58 AM
Quick Reply: d16 civic misfire problem, help!
