VTEC Not Working??? PLEASE HELP!!!
Old Oct 16, 2008 | 03:01 PM
909dc2's Avatar
Default VTEC Not Working??? PLEASE HELP!!!
I have a '94 Integra GSR with a B18C1 block and a B16A3 head with a P72 ECU. It has good power until about 4500 RPM, once the RPM's raise past that it starts to lag and at around 7000 RPM it feels like it wont go any higher and then the Battery Light starts to flash. An I dont hear the VTEC at all...
After checking the other day I found out I have the ECU codes <U>17(VSS)</U> and <U>23(KS)</U> going off.
Old Oct 16, 2008 | 03:19 PM
4drdohc's Avatar
Default Re: VTEC Not Working??? PLEASE HELP!!! (909dc2)
check your oil level, and your vtec selenoids.
Old Oct 16, 2008 | 03:20 PM
sivik_outkast's Avatar
Yeah, the vtec won't engage if the oil is low
Old Oct 16, 2008 | 03:22 PM
BoSox46GSr's Avatar
Default Re: (sivik_outkast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drdohc &raquo;</TD></TR><TR><TD CLASS="quote">check your oil level, and your vtec selenoids. </TD></TR></TABLE>
Only one solenoid...
I would adress the issue you know is there before you jump to anything else.
Knock Sensor is your reason for no VTEC.
Old Oct 16, 2008 | 03:29 PM
4drdohc's Avatar
Default Re: (BoSox46GSr)
you know what i mean, i just usually tend to put an "S" on things haha, and bosox your signature is hilarious hahahaha
Old Oct 16, 2008 | 03:36 PM
909dc2's Avatar
Default Re: (4drdohc)
Yea I'll look into that next I bearly bought the VSS but not the KS. But my oil level is fine. Thanks...
Old Oct 16, 2008 | 03:40 PM
BoSox46GSr's Avatar
Default Re: (909dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 909dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Yea I'll look into that next I bearly bought the VSS but not the KS. But my oil level is fine. Thanks... </TD></TR></TABLE>
Kinda confused... how do you "barely buy" something? It might not be a problem with the knock sensor. It picks up on abnormal vibration in the engine. It might be something internal.
Old Oct 16, 2008 | 06:54 PM
vietnamezerice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoSox46GSr &raquo;</TD></TR><TR><TD CLASS="quote">
Kinda confused... how do you "barely buy" something? It might not be a problem with the knock sensor. It picks up on abnormal vibration in the engine. It might be something internal. </TD></TR></TABLE>
Old Oct 16, 2008 | 07:13 PM
weavertime1's Avatar
Default Re: (vietnamezerice)
If you have a code for Knock Sensor, VTEC will not engage...that simple. Figure out the knock sensor issue, and vtec should work...BTW it is possible for the ecu to be faulty in this case...look into it.
Old Oct 16, 2008 | 07:14 PM
Default Re: (weavertime1)
replace/test the knock sensor... if problems still persist then try another ecu
Old Oct 16, 2008 | 07:43 PM
HONDRETTI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weavertime1 &raquo;</TD></TR><TR><TD CLASS="quote">If you have a code for Knock Sensor, VTEC will not engage...that simple. Figure out the knock sensor issue, and vtec should work...BTW it is possible for the ecu to be faulty in this case...look into it. </TD></TR></TABLE>
i already heard that this may vary, but when i had my b16 i constantly ran with cel 23 and vtec cracked.
Old Oct 16, 2008 | 11:26 PM
Default Re: (HONDRETTI)
hmm... that's strange
Old Oct 17, 2008 | 03:32 AM
90SiReX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 909dc2 &raquo;</TD></TR><TR><TD CLASS="quote">I have a '94 Integra GSR with a B18C1 block and a B16A3 head with a P72 ECU. It has good power until about 4500 RPM, once the RPM's raise past that it starts to lag and at around 7000 RPM it feels like it wont go any higher and then the Battery Light starts to flash. An I dont hear the VTEC at all...
After checking the other day I found out I have the ECU codes <U>17(VSS)</U> and <U>23(KS)</U> going off. </TD></TR></TABLE>
when you fix your CEL problem u might wanna change out that ECU. if im not mistaken P72 is a GSR ecu, and with a single stange IM off the B16 it might not run that great. but i could be wrong just my .02 someone correct me if im wrong.
S_StarGsr
Apr 29, 2017 08:24 AM
Lauj87
Jun 28, 2005 11:46 AM
b16mike
May 13, 2005 09:51 PM
Ch3mik
20
Mar 30, 2005 11:56 PM
acdracing
Dec 13, 2004 06:13 PM
