vtec help
Old Dec 2, 2004 | 11:42 AM
STUCKED's Avatar
Default vtec help
i have a '95 gsr and there are problems with the vtec. my friends sway it doesnt work and im starting to believe that. you can hear it engaging but you cant feel it. what could be wrong? it has aem cam gears and its not at top dead center. i believe the previous owner did some engine tuning. any help would be appreciated. thanks
Old Dec 2, 2004 | 11:49 AM
Slain's Avatar
any check engine lights....oil level, coolant level
Old Dec 2, 2004 | 11:58 AM
STUCKED's Avatar
Default Re: (Slain)
nothing lights ups... as if nothing was wrong???????????
Old Dec 2, 2004 | 01:36 PM
Hulkdon1's Avatar
Default Re: vtec help (STUCKED)
If you can here the Vtec but it feels like you're not moving as fast, then the timing on the cam gears are definetely off. Have the timming adjusted to the correct position by someone who knows what they're doing. If you have a good exhaust (free flowing) you should feel the difference.
Old Dec 6, 2004 | 11:20 AM
STUCKED's Avatar
Default Re: vtec help (Hulkdon1)
the timing is definitely off. i took the valve cover offf once to check why oil was leaking and viola cam gears and camshafts that were not at top dead center. so resetting the timine might help. will get rigth on that. thanks. any other suggestions because the previous owner must of knew what he/she was doing to change the timing... any help wanted and needed and is greatly appreaciated.
Old Dec 9, 2004 | 05:12 PM
STUCKED's Avatar
tried and tried and tried. still not working... c'mon honda freaks help me out
Old Dec 13, 2004 | 05:42 PM
STUCKED's Avatar
oh well... i guess fellow honda enthuasists arent that help full...
Old Dec 13, 2004 | 05:47 PM
campbuds's Avatar
first off don't be a jerk about it.
second if you hear it engaging then it probably is. The Vtec DOES NOT throw you back in your seat, it is actaully kinda subtle, and even on my supercharged motor, which amplifies the affect VTEC has, you still can miss it kicking in if you don't pay attention.
IF you have an intake and quiet exhaust you should be able to hear it clearly in the sound coming from the intake. BUT if your exhaust is loud enough it will muffle out your intake noise.
Old Dec 13, 2004 | 05:55 PM
STUCKED's Avatar
Default Re: (campbuds)
what gives........... the car is bone stock with cam gears and the timing is off.. there is a chance there could be cam shafts too. not quite sure though
Old Dec 13, 2004 | 05:57 PM
ian.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by campbuds &raquo;</TD></TR><TR><TD CLASS="quote">first off don't be a jerk about it.
IF you have an intake and quiet exhaust you should be able to hear it clearly in the sound coming from the intake. BUT if your exhaust is loud enough it will muffle out your intake noise.</TD></TR></TABLE>
wise words from an 04 classmate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STUCKED &raquo;</TD></TR><TR><TD CLASS="quote">the timing is definitely off. i took the valve cover offf once to check why oil was leaking and viola cam gears and camshafts that were not at top dead center. so resetting the timine might help. will get rigth on that. thanks. any other suggestions because the previous owner must of knew what he/she was doing to change the timing... any help wanted and needed and is greatly appreaciated. </TD></TR></TABLE>
fix the timing then see what happens
Old Dec 13, 2004 | 06:02 PM
flipldls's Avatar
Default Question here
ya i hav a question for u ppl wut wld b better ITR camshaft or aftermarket camshaft...............wut wld work best for my 95 gsr
Old Dec 13, 2004 | 06:04 PM
ian.'s Avatar
Default Re: Question here (flipldls)
i would go with ctr they have 3 more degrees duration over the itr but its not a huge deal
killerbseries
Apr 23, 2005 08:10 PM
John
Dec 28, 2003 07:44 PM
dallasyoung
May 12, 2003 09:12 PM
vtec69
Jan 10, 2003 04:56 PM
